Qué necesitas
Power off the device
Remove any cables that might be connected to your device
Make sure the device is placed on a flat surface with the display screen facing up
Use your fingers to pull back and remove the yellow plastic tape covering the battery cable.
6 personas más completaron esta guía.
3 comentarios
It looks like not too hard to fix it
Hello, what are white and yellow cables, could I somehow replace original battery with generic (2 wire lipo - cheaper one) . can those 2 wires be cut and could tablet work? thanks
Hello , can I replace this 4 wire battery with 2 wire generic one ? What are white and yellow cables , could they be removed or somehow reconnected for use of 2 wire (red and black) generic tablet battery. Thanks
