Saltar al contenido principal
Acer Iconia Tab 8 A1-840 Battery Replacement
Qué necesitas
  1. Acer Iconia Tab 8 A1-840 Battery Replacement, Back Panel: paso 1, imagen 1 de 1
    • Power off the device
    • Remove any cables that might be connected to your device
    • Make sure the device is placed on a flat surface with the display screen facing up
  2. Acer Iconia Tab 8 A1-840 Battery Replacement: paso 2, imagen 1 de 1
    • Wedge the plastic opening tool in between the display screen and back panel
    • Do not apply too much pressure in order to avoid cracking the screen
  3. Acer Iconia Tab 8 A1-840 Battery Replacement: paso 3, imagen 1 de 1
    • Carefully separate the display from the back panel
  4. Acer Iconia Tab 8 A1-840 Battery Replacement, Battery: paso 4, imagen 1 de 1
    • Use your fingers to pull back and remove the yellow plastic tape covering the battery cable.
  5. Acer Iconia Tab 8 A1-840 Battery Replacement: paso 5, imagen 1 de 1
    • Use the flat end of the spudger to pry up and remove the battery cable.
  6. Acer Iconia Tab 8 A1-840 Battery Replacement: paso 6, imagen 1 de 1
    • Use the flat side of the heavy duty spudger to lift the small black plastic flap.
  7. Acer Iconia Tab 8 A1-840 Battery Replacement: paso 7, imagen 1 de 1
    • Use fingers to pull the Zero Insertion Force (ZIF) cable from the motherboard.
  8. Acer Iconia Tab 8 A1-840 Battery Replacement: paso 8, imagen 1 de 1
    • Use fingers to remove the smaller adjacent ZIF cable from the motherboard.
  9. Acer Iconia Tab 8 A1-840 Battery Replacement: paso 9, imagen 1 de 1
    • Use the flat end of the spudger to pry the battery up from all edges, and remove it from the back panel.
    • There is adhesive behind the battery that holds it in place. Be sure to pry slowly and carefully when removing the battery.
Conclusión
6 personas más completaron esta guía.
Claire Posadas
Miembro Desde 10/18/16
396 Reputación
3 Guías creadas
Equipo
UW Tacoma, Team 1-1, Rose Fall 2016 Miembro de UW Tacoma, Team 1-1, Rose Fall 2016
UWT-ROSE-F16S1G1
4 Miembros
6 Guías creadas
3 comentarios
It looks like not too hard to fix it
Guerry's Som - Contestar
Hello, what are white and yellow cables, could I somehow replace original battery with generic (2 wire lipo - cheaper one) . can those 2 wires be cut and could tablet work? thanks
Milan Lazić - Contestar
Hello , can I replace this 4 wire battery with 2 wire generic one ? What are white and yellow cables , could they be removed or somehow reconnected for use of 2 wire (red and black) generic tablet battery. Thanks
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 4
Ultimos 30 días: 18
Todo El Tiempo: 5,343
