Saltar al contenido principal
Acer Iconia One 8 Battery Replacement
Qué necesitas
  1. Acer Iconia One 8 Battery Replacement, Battery: paso 1, imagen 1 de 2 Acer Iconia One 8 Battery Replacement, Battery: paso 1, imagen 2 de 2
    • To remove the back panel, insert an opening tool into the small crack between the screen and back panel. Gently pry open the tablet.
  2. Acer Iconia One 8 Battery Replacement: paso 2, imagen 1 de 1
    • Remove the black piece of tape that is holding the red, yellow, and white wires in place.
  3. Acer Iconia One 8 Battery Replacement: paso 3, imagen 1 de 1
    • Once the tape has been removed, gently pinch the wires and remove them from the socket. They should come out easily.
  4. Acer Iconia One 8 Battery Replacement: paso 4, imagen 1 de 1
    • Carefully work a plastic spudger underneath the battery and pry it free.
    • Use an iOpener or carefully apply heat with a heat gun to soften the adhesive under the battery.
    • Be careful not to bend or puncture the battery.
Conclusión
2 personas más completaron esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 4
Ultimos 30 días: 10
Todo El Tiempo: 2,848
