Introducción
We dismantled the Acer Iconia One 7 and found it to be extremely repairable with only 8 components.
Partes
No se especificaron partes.
The display, digitizer, and camera cables can be disconnected without removing the motherboard.
The motherboard is secured to the display frame by three Phillips #0 screws.
The Micro-USB port, headphone jack and microphone are soldered to the motherboard. These are common failure points and it would be better if they could be individually replaced.
The front and rear camera are tethered and will need to be replaced together if one where to fail.
The Acer Iconia One 7 earns an 8 out of 10 on our repairability scale (10 is the easiest to repair):
LCD and front glass are not fused and can be replaced individually.
Battery is easy to replace.
Modular design allows replacement of many individual parts.
Standard Phillips screws used throughout.
High wear components soldered in place, which increases replacement costs.
Manufacturer does not provide user-accessible repair documentation.
7 personas más completaron esta guía.
5 comentarios
I have an Acer Iconia tablet A500, 32GB RAM, 1GB ROM
I would like to increase my ROM to 4GB ROM, is it possible.
Can you recommend someone or a place that can do this for me?
Thanks, Ginger
email address: ginger41558@outlook.com
I have used it very little, sat quietly in a drawer - when I decided to use it, it won’t power up! Sometimes it shows a splash screen with one word on it - ACER (if I remember right). Any idea what might be going on, I’d be grateful - would even give it to someone to revive and use
Estuvo excelente. Gracias y saludos.
Is this Acer Iconia One 7 B1-780 (2017) or the older 2014 version?
