Saltar al contenido principal
Acer Iconia One 7 Rear-Facing Camera Replacement
Qué necesitas
  1. Acer Iconia One 7 Rear-Facing Camera Replacement, Rear-Facing Camera: paso 1, imagen 1 de 1
    • Begin at any side of the tablet.
    • With a plastic opening tool, begin taking apart the back cover from the tablet by working along the edges.
    • Prying the lid open can be difficult, use caution in order to safely remove.
    • Turn off device before this step.
  2. Acer Iconia One 7 Rear-Facing Camera Replacement: paso 2, imagen 1 de 1
    • Using a plastic opening tool, separate the back cover from the main device.
    • Open each side continuously to ensure all sides have been separated.
  3. Acer Iconia One 7 Rear-Facing Camera Replacement: paso 3, imagen 1 de 1
    • Turn the tablet over to locate the camera on the top left.
    • Besides the parts that are mentioned in the instruction, try not to agitate other fragile components inside the device.
  4. Acer Iconia One 7 Rear-Facing Camera Replacement: paso 4, imagen 1 de 2 Acer Iconia One 7 Rear-Facing Camera Replacement: paso 4, imagen 2 de 2
    • Peel black tape.
    • Detach clip from motherboard.
  5. Acer Iconia One 7 Rear-Facing Camera Replacement: paso 5, imagen 1 de 2 Acer Iconia One 7 Rear-Facing Camera Replacement: paso 5, imagen 2 de 2
    • Take out film object using tweezers.
    • Using tweezers take out camera.
Conclusión
Michael
Miembro Desde 09/03/15
519 Reputación
4 Guías creadas
Equipo
USF Tampa, Team 8-5, Eyestone Fall 2015 Miembro de USF Tampa, Team 8-5, Eyestone Fall 2015
USFT-EYESTONE-F15S8G5
3 Miembros
5 Guías creadas
Un comentario
How to get new camera if the original camera is damaged
Prakash Hasabnis - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 6
Ultimos 30 días: 7
Todo El Tiempo: 421
