Saltar al contenido principal
Acer Iconia One 7 Motherboard Replacement
Qué necesitas
    • Reminder: Turn off device before you start opening your tablet.
  1. Acer Iconia One 7 Motherboard Replacement: paso 2, imagen 1 de 1
    • Begin at any side of the tablet.
    • With a plastic opening tool, begin taking apart the back cover from the tablet by working along the edges.
    • Use caution when prying the lid open to avoid damaging your tablet.
  2. Acer Iconia One 7 Motherboard Replacement: paso 3, imagen 1 de 1
    • Using a plastic opening tool, separate the back cover from the main device
    • Open each side continuously to ensure all sides have been separated,
  3. Acer Iconia One 7 Motherboard Replacement: paso 4, imagen 1 de 1
    • Turn tablet over.
    • Lay the tablet on a flat surface with the screen facing down. Locate the copper cover along the outside of the tablet.
  4. Acer Iconia One 7 Motherboard Replacement: paso 5, imagen 1 de 1
    • Carefully peel back the copper foil to reveal the motherboard.
  5. Acer Iconia One 7 Motherboard Replacement: paso 6, imagen 1 de 1
    • Peel tape back to expose connections.
  6. Acer Iconia One 7 Motherboard Replacement: paso 7, imagen 1 de 2 Acer Iconia One 7 Motherboard Replacement: paso 7, imagen 2 de 2
    • There are several sets of wires connected to the motherboard as shown in the images. Carefully disconnect each set of wires.
  7. Acer Iconia One 7 Motherboard Replacement: paso 8, imagen 1 de 2 Acer Iconia One 7 Motherboard Replacement: paso 8, imagen 2 de 2
    • Use a JIS screw bit #00 to remove screws around the motherboard using the provided image to locate each screw.
  8. Acer Iconia One 7 Motherboard Replacement: paso 9, imagen 1 de 1
    • Gently pull out motherboard.
Conclusión
4 personas más completaron esta guía.
Michael
Miembro Desde 09/03/15
519 Reputación
4 Guías creadas
Equipo
USF Tampa, Team 8-5, Eyestone Fall 2015 Miembro de USF Tampa, Team 8-5, Eyestone Fall 2015
USFT-EYESTONE-F15S8G5
3 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 9
Todo El Tiempo: 2,572
