Saltar al contenido principal
Acer Iconia One 7 Battery Replacement
Qué necesitas
  1. Acer Iconia One 7 Battery Replacement, Battery: paso 1, imagen 1 de 1
    • Begin prying the front from the back on any side of the tablet. Gently work your way around the tablet with the prying tool.
  2. Acer Iconia One 7 Battery Replacement: paso 2, imagen 1 de 1
    • Using a plastic opening tool, separate the back cover from the main device.
    • Open each side continuously to ensure all sides have been separated.
  3. Acer Iconia One 7 Battery Replacement: paso 3, imagen 1 de 1
    • Turn the tablet over so the battery is facing up.
  4. Acer Iconia One 7 Battery Replacement: paso 4, imagen 1 de 2 Acer Iconia One 7 Battery Replacement: paso 4, imagen 2 de 2
    • Carefully pull back the black tape covering the battery lead connector.
    • Disconnect connection with the board by pulling up on the wire with the plastic opening tool.
  5. Acer Iconia One 7 Battery Replacement: paso 5, imagen 1 de 3 Acer Iconia One 7 Battery Replacement: paso 5, imagen 2 de 3 Acer Iconia One 7 Battery Replacement: paso 5, imagen 3 de 3
    Herramienta utilizada en este paso:
    Plastic Cards
    $2.99
    Comprar
    • Using a plastic card or opening pick, separate the battery from the rest of the device.
    • Do not use a metal spudger like seen in the example photos. Use a plastic card to avoid bending or rupturing the battery.
Conclusión
6 personas más completaron esta guía.
Ahmad Kayali
Miembro Desde 09/01/15
458 Reputación
1 Guía escrita
Equipo
USF Tampa, Team 8-5, Eyestone Fall 2015 Miembro de USF Tampa, Team 8-5, Eyestone Fall 2015
USFT-EYESTONE-F15S8G5
3 Miembros
5 Guías creadas
4 comentarios
is there a replacement batt that can fit here or other brand that can fit? like from samsing tab? acer battery sucks
Stanley So - Contestar
Thank you for this guide, replaced my battery (very easy with guide) and now my tablet works good. Also saved me some money. Thanks
vlamar14 - Contestar
My acer iconia one 7 battery model is 308292 wnd there is no tutorial regarding replacing battery. Thank
wantalktasol - Contestar
Where I can order the new battery part?
melanieloa3 - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 3
Ultimos 30 días: 32
Todo El Tiempo: 18,363
