Saltar al contenido principal
Acer Iconia B1-720 Rear Case Replacement
Qué necesitas
  1. Acer Iconia B1-720 Rear Case Replacement, Rear Case: paso 1, imagen 1 de 3 Acer Iconia B1-720 Rear Case Replacement, Rear Case: paso 1, imagen 2 de 3 Acer Iconia B1-720 Rear Case Replacement, Rear Case: paso 1, imagen 3 de 3
    • Insert a plastic opening tool into a gap near the charging port at the top of the device. Slide the tool in either direction along the device.
  2. Acer Iconia B1-720 Rear Case Replacement: paso 2, imagen 1 de 3 Acer Iconia B1-720 Rear Case Replacement: paso 2, imagen 2 de 3 Acer Iconia B1-720 Rear Case Replacement: paso 2, imagen 3 de 3
    • Slide the tool along until you have completely separated the rear cover.
    • If needed, place the first tool in the gap created to hold this gap open and use a second tool to pry the remaining portion of the rear cover off.
  3. Acer Iconia B1-720 Rear Case Replacement: paso 3, imagen 1 de 2 Acer Iconia B1-720 Rear Case Replacement: paso 3, imagen 2 de 2
    • Once all the sides have been separated, you should be able to simply lift the cover off of the device.
Conclusión
2 personas más completaron esta guía.
Phillip Keavey
Miembro Desde 03/17/15
319 Reputación
2 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 7
Todo El Tiempo: 841
