Saltar al contenido principal
Acer Iconia B1-720 Motherboard Replacement
Qué necesitas
  1. Acer Iconia B1-720 Motherboard Replacement, Rear Case: paso 1, imagen 1 de 3 Acer Iconia B1-720 Motherboard Replacement, Rear Case: paso 1, imagen 2 de 3 Acer Iconia B1-720 Motherboard Replacement, Rear Case: paso 1, imagen 3 de 3
    • Insert a plastic opening tool into a gap near the charging port at the top of the device. Slide the tool in either direction along the device.
  2. Acer Iconia B1-720 Motherboard Replacement: paso 2, imagen 1 de 3 Acer Iconia B1-720 Motherboard Replacement: paso 2, imagen 2 de 3 Acer Iconia B1-720 Motherboard Replacement: paso 2, imagen 3 de 3
    • Slide the tool along until you have completely separated the rear cover.
    • If needed, place the first tool in the gap created to hold this gap open and use a second tool to pry the remaining portion of the rear cover off.
  3. Acer Iconia B1-720 Motherboard Replacement: paso 3, imagen 1 de 2 Acer Iconia B1-720 Motherboard Replacement: paso 3, imagen 2 de 2
    • Once all the sides have been separated, you should be able to simply lift the cover off of the device.
  4. Acer Iconia B1-720 Motherboard Replacement, Battery: paso 4, imagen 1 de 2 Acer Iconia B1-720 Motherboard Replacement, Battery: paso 4, imagen 2 de 2
    • Peel back the plastic tape covering the battery connector.
  5. Acer Iconia B1-720 Motherboard Replacement: paso 5, imagen 1 de 1
    • Use the plastic opening tool to lift the battery off of the back panel. The adhesive used is strong so apply force during removal.
  6. Acer Iconia B1-720 Motherboard Replacement: paso 6, imagen 1 de 3 Acer Iconia B1-720 Motherboard Replacement: paso 6, imagen 2 de 3 Acer Iconia B1-720 Motherboard Replacement: paso 6, imagen 3 de 3
    • Lift the battery off of the panel gently. This will disconnect the battery connector from the motherboard.
  7. Acer Iconia B1-720 Motherboard Replacement, Microphone/Speaker: paso 7, imagen 1 de 3 Acer Iconia B1-720 Motherboard Replacement, Microphone/Speaker: paso 7, imagen 2 de 3 Acer Iconia B1-720 Motherboard Replacement, Microphone/Speaker: paso 7, imagen 3 de 3
    • Pry the speaker away from the device using the plastic opening tool. This may require a little force due to the adhesive that is on the device.(Battery is not shown in this picture for image
    • Tug gently on microphone to remove from slot.
  8. Acer Iconia B1-720 Motherboard Replacement: paso 8, imagen 1 de 2 Acer Iconia B1-720 Motherboard Replacement: paso 8, imagen 2 de 2
    • Unwind the wire from the running channel.
    • To remove microphone, follow same steps.
  9. Acer Iconia B1-720 Motherboard Replacement: paso 9, imagen 1 de 2 Acer Iconia B1-720 Motherboard Replacement: paso 9, imagen 2 de 2
    • Unplug connector from motherboard.
    • Follow same procedure to remove microphone.
    • Unplug the microphone in a similar fashion as with the speaker.
  10. Acer Iconia B1-720 Motherboard Replacement, Motherboard: paso 10, imagen 1 de 3 Acer Iconia B1-720 Motherboard Replacement, Motherboard: paso 10, imagen 2 de 3 Acer Iconia B1-720 Motherboard Replacement, Motherboard: paso 10, imagen 3 de 3
    • Remove the yellow tape covering both ribbons in the two photos shown.
  11. Acer Iconia B1-720 Motherboard Replacement: paso 11, imagen 1 de 2 Acer Iconia B1-720 Motherboard Replacement: paso 11, imagen 2 de 2
    Herramienta utilizada en este paso:
    Comprar
    • Use tweezers to lift the small black locking tab off of the orange ribbon
    • Remove the orange ribbon from the lock using tweezers
  12. Acer Iconia B1-720 Motherboard Replacement: paso 12, imagen 1 de 3 Acer Iconia B1-720 Motherboard Replacement: paso 12, imagen 2 de 3 Acer Iconia B1-720 Motherboard Replacement: paso 12, imagen 3 de 3
    • Use tweezers to remove rubber black wrap surrounding lock.
    • Use the tweezers to pull plastic tabs on each side of the black ribbon
  13. Acer Iconia B1-720 Motherboard Replacement: paso 13, imagen 1 de 2 Acer Iconia B1-720 Motherboard Replacement: paso 13, imagen 2 de 2
    • Use tweezers to gently remove black ribbon from locking mechanism.
  14. Acer Iconia B1-720 Motherboard Replacement: paso 14, imagen 1 de 3 Acer Iconia B1-720 Motherboard Replacement: paso 14, imagen 2 de 3 Acer Iconia B1-720 Motherboard Replacement: paso 14, imagen 3 de 3
    • Remove the 5 screws shown in the photograph
    • Lift the motherboard from the front panel of the device.
Conclusión
Una persona más ha completado esta guía.
Kervis Boston
Miembro Desde 03/18/15
479 Reputación
3 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 3
Ultimos 30 días: 13
Todo El Tiempo: 1,418
