Saltar al contenido principal
Acer Iconia B1-720 Microphone/Speaker Replacement
Qué necesitas
  1. Acer Iconia B1-720 Microphone/Speaker Replacement, Rear Case: paso 1, imagen 1 de 3 Acer Iconia B1-720 Microphone/Speaker Replacement, Rear Case: paso 1, imagen 2 de 3 Acer Iconia B1-720 Microphone/Speaker Replacement, Rear Case: paso 1, imagen 3 de 3
    • Insert a plastic opening tool into a gap near the charging port at the top of the device. Slide the tool in either direction along the device.
  2. Acer Iconia B1-720 Microphone/Speaker Replacement: paso 2, imagen 1 de 3 Acer Iconia B1-720 Microphone/Speaker Replacement: paso 2, imagen 2 de 3 Acer Iconia B1-720 Microphone/Speaker Replacement: paso 2, imagen 3 de 3
    • Slide the tool along until you have completely separated the rear cover.
    • If needed, place the first tool in the gap created to hold this gap open and use a second tool to pry the remaining portion of the rear cover off.
  3. Acer Iconia B1-720 Microphone/Speaker Replacement: paso 3, imagen 1 de 2 Acer Iconia B1-720 Microphone/Speaker Replacement: paso 3, imagen 2 de 2
    • Once all the sides have been separated, you should be able to simply lift the cover off of the device.
  4. Acer Iconia B1-720 Microphone/Speaker Replacement, Microphone/Speaker: paso 4, imagen 1 de 3 Acer Iconia B1-720 Microphone/Speaker Replacement, Microphone/Speaker: paso 4, imagen 2 de 3 Acer Iconia B1-720 Microphone/Speaker Replacement, Microphone/Speaker: paso 4, imagen 3 de 3
    • Pry the speaker away from the device using the plastic opening tool. This may require a little force due to the adhesive that is on the device.(Battery is not shown in this picture for image
    • Tug gently on microphone to remove from slot.
  5. Acer Iconia B1-720 Microphone/Speaker Replacement: paso 5, imagen 1 de 2 Acer Iconia B1-720 Microphone/Speaker Replacement: paso 5, imagen 2 de 2
    • Unwind the wire from the running channel.
    • To remove microphone, follow same steps.
  6. Acer Iconia B1-720 Microphone/Speaker Replacement: paso 6, imagen 1 de 2 Acer Iconia B1-720 Microphone/Speaker Replacement: paso 6, imagen 2 de 2
    • Unplug connector from motherboard.
    • Follow same procedure to remove microphone.
    • Unplug the microphone in a similar fashion as with the speaker.
Conclusión
Phillip Keavey
Miembro Desde 03/17/15
319 Reputación
2 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 3
Ultimos 30 días: 8
Todo El Tiempo: 692
