Saltar al contenido principal
Acer Iconia B1-720 Front Facing Camera Replacement
Qué necesitas
  1. Acer Iconia B1-720 Front Facing Camera Replacement, Rear Case: paso 1, imagen 1 de 3 Acer Iconia B1-720 Front Facing Camera Replacement, Rear Case: paso 1, imagen 2 de 3 Acer Iconia B1-720 Front Facing Camera Replacement, Rear Case: paso 1, imagen 3 de 3
    • Insert a plastic opening tool into a gap near the charging port at the top of the device. Slide the tool in either direction along the device.
  2. Acer Iconia B1-720 Front Facing Camera Replacement: paso 2, imagen 1 de 3 Acer Iconia B1-720 Front Facing Camera Replacement: paso 2, imagen 2 de 3 Acer Iconia B1-720 Front Facing Camera Replacement: paso 2, imagen 3 de 3
    • Slide the tool along until you have completely separated the rear cover.
    • If needed, place the first tool in the gap created to hold this gap open and use a second tool to pry the remaining portion of the rear cover off.
  3. Acer Iconia B1-720 Front Facing Camera Replacement: paso 3, imagen 1 de 2 Acer Iconia B1-720 Front Facing Camera Replacement: paso 3, imagen 2 de 2
    • Once all the sides have been separated, you should be able to simply lift the cover off of the device.
  4. Acer Iconia B1-720 Front Facing Camera Replacement, Microphone/Speaker: paso 4, imagen 1 de 3 Acer Iconia B1-720 Front Facing Camera Replacement, Microphone/Speaker: paso 4, imagen 2 de 3 Acer Iconia B1-720 Front Facing Camera Replacement, Microphone/Speaker: paso 4, imagen 3 de 3
    • Pry the speaker away from the device using the plastic opening tool. This may require a little force due to the adhesive that is on the device.(Battery is not shown in this picture for image
    • Tug gently on microphone to remove from slot.
  5. Acer Iconia B1-720 Front Facing Camera Replacement: paso 5, imagen 1 de 2 Acer Iconia B1-720 Front Facing Camera Replacement: paso 5, imagen 2 de 2
    • Unwind the wire from the running channel.
    • To remove microphone, follow same steps.
  6. Acer Iconia B1-720 Front Facing Camera Replacement: paso 6, imagen 1 de 2 Acer Iconia B1-720 Front Facing Camera Replacement: paso 6, imagen 2 de 2
    • Unplug connector from motherboard.
    • Follow same procedure to remove microphone.
    • Unplug the microphone in a similar fashion as with the speaker.
  7. Acer Iconia B1-720 Front Facing Camera Replacement, Motherboard: paso 7, imagen 1 de 3 Acer Iconia B1-720 Front Facing Camera Replacement, Motherboard: paso 7, imagen 2 de 3 Acer Iconia B1-720 Front Facing Camera Replacement, Motherboard: paso 7, imagen 3 de 3
    • Remove the yellow tape covering both ribbons in the two photos shown.
  8. Acer Iconia B1-720 Front Facing Camera Replacement: paso 8, imagen 1 de 2 Acer Iconia B1-720 Front Facing Camera Replacement: paso 8, imagen 2 de 2
    Herramienta utilizada en este paso:
    Comprar
    • Use tweezers to lift the small black locking tab off of the orange ribbon
    • Remove the orange ribbon from the lock using tweezers
  9. Acer Iconia B1-720 Front Facing Camera Replacement: paso 9, imagen 1 de 3 Acer Iconia B1-720 Front Facing Camera Replacement: paso 9, imagen 2 de 3 Acer Iconia B1-720 Front Facing Camera Replacement: paso 9, imagen 3 de 3
    • Use tweezers to remove rubber black wrap surrounding lock.
    • Use the tweezers to pull plastic tabs on each side of the black ribbon
  10. Acer Iconia B1-720 Front Facing Camera Replacement: paso 10, imagen 1 de 2 Acer Iconia B1-720 Front Facing Camera Replacement: paso 10, imagen 2 de 2
    • Use tweezers to gently remove black ribbon from locking mechanism.
  11. Acer Iconia B1-720 Front Facing Camera Replacement: paso 11, imagen 1 de 3 Acer Iconia B1-720 Front Facing Camera Replacement: paso 11, imagen 2 de 3 Acer Iconia B1-720 Front Facing Camera Replacement: paso 11, imagen 3 de 3
    • Remove the 5 screws shown in the photograph
    • Lift the motherboard from the front panel of the device.
  12. Acer Iconia B1-720 Front Facing Camera Replacement, Front Facing Camera: paso 12, imagen 1 de 1
    • Flip the motherboard over so that you see the camera, micro usb port, and headphone jack.
    • The object marked in red is the camera.
  13. Acer Iconia B1-720 Front Facing Camera Replacement: paso 13, imagen 1 de 2 Acer Iconia B1-720 Front Facing Camera Replacement: paso 13, imagen 2 de 2
    • Grab and gently lift the camera up from the motherboard until it becomes disconnected.
Conclusión
Una persona más ha completado esta guía.
Kervis Boston
Miembro Desde 03/18/15
479 Reputación
3 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 5
Todo El Tiempo: 399
