Saltar al contenido principal
Acer Iconia B1-720 Battery Replacement
Qué necesitas
  1. Acer Iconia B1-720 Battery Replacement, Rear Case: paso 1, imagen 1 de 3 Acer Iconia B1-720 Battery Replacement, Rear Case: paso 1, imagen 2 de 3 Acer Iconia B1-720 Battery Replacement, Rear Case: paso 1, imagen 3 de 3
    • Insert a plastic opening tool into a gap near the charging port at the top of the device. Slide the tool in either direction along the device.
  2. Acer Iconia B1-720 Battery Replacement: paso 2, imagen 1 de 3 Acer Iconia B1-720 Battery Replacement: paso 2, imagen 2 de 3 Acer Iconia B1-720 Battery Replacement: paso 2, imagen 3 de 3
    • Slide the tool along until you have completely separated the rear cover.
    • If needed, place the first tool in the gap created to hold this gap open and use a second tool to pry the remaining portion of the rear cover off.
  3. Acer Iconia B1-720 Battery Replacement: paso 3, imagen 1 de 2 Acer Iconia B1-720 Battery Replacement: paso 3, imagen 2 de 2
    • Once all the sides have been separated, you should be able to simply lift the cover off of the device.
  4. Acer Iconia B1-720 Battery Replacement, Battery: paso 4, imagen 1 de 2 Acer Iconia B1-720 Battery Replacement, Battery: paso 4, imagen 2 de 2
    • Peel back the plastic tape covering the battery connector.
  5. Acer Iconia B1-720 Battery Replacement: paso 5, imagen 1 de 1
    • Use the plastic opening tool to lift the battery off of the back panel. The adhesive used is strong so apply force during removal.
  6. Acer Iconia B1-720 Battery Replacement: paso 6, imagen 1 de 3 Acer Iconia B1-720 Battery Replacement: paso 6, imagen 2 de 3 Acer Iconia B1-720 Battery Replacement: paso 6, imagen 3 de 3
    • Lift the battery off of the panel gently. This will disconnect the battery connector from the motherboard.
Conclusión
5 personas más completaron esta guía.
Kervis Boston
Miembro Desde 03/18/15
479 Reputación
3 Guías creadas
Equipo
2 comentarios
Why the battery has a 4 pin connector? I tried to buy another generic battery but it got only 2 cables, don't know how to replace :(
Tadeu - Contestar
I just wanted to throw a red flag out there…I broke my connector off the motherboard trying to reinstall the four-pin connection…can anyone advise?
John Merritt - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 8
Todo El Tiempo: 2,884
