Introducción
This guide serves to help the user replace the motherboard on the Acer Iconia Tab A100.
The motherboard can serve as the root of many issues. It is the brain of the machine and is key to the operations of a computer.
Warning: The motherboard is an extremely delicate part of the computer and should be handled with utmost care. It is recommended to wear gloves when touching a motherboard because it is very sensitive to electricity.
Qué necesitas
Start at any side of the tablet.
Begin to take apart the tablet with a plastic opening tool along the sides of the tablet.
Work your way around the tablet.
Locate the light sensor connector.
Use the tip of a spudger or your fingernail to lift up and flip the small retaining flap on the connector. The light sensor ribbon cable should now be free, so simply pull it out.
Use a Phillips #00 screwdriver to unscrew the single 3.0mm Phillips screw next to the light sensor connector.
Locate the speakers module, which consists of 2 square black speakers connected by wires.
Locate the white and blue Home Key FFC ribbon cable between the speakers.
Use the tip of a spudger or opening tool to lift up and flip the small hinge on the connector. Then gently pull the FFC ribbon cable out its connector socket.
Use the tip of a spudger or your fingernail to flip up the retaining flap on the connector.
Use your fingers to gently pull the orange cable out of the connector socket.
