Saltar al contenido principal
Acer Iconia A100 Battery Replacement
Qué necesitas
  1. Acer Iconia A100 Battery Replacement, Battery: paso 1, imagen 1 de 1
    • Start at any side of the tablet.
    • Begin to take apart the tablet with a plastic opening tool along the sides of the tablet.
    • Work your way around the tablet.
    • There are four side pieces in total.
  2. Acer Iconia A100 Battery Replacement: paso 2, imagen 1 de 1
    • Remove the five 4 mm screws from the edges of the tablet with a Phillips #00 screwdriver.
  3. Acer Iconia A100 Battery Replacement: paso 3, imagen 1 de 1
    • Carefully separate the back piece from the device using a plastic opening tool.
    • Remember to open along the entire perimeter of the tablet.
  4. Acer Iconia A100 Battery Replacement: paso 4, imagen 1 de 1
    • Turn the tablet over so that the battery is facing upwards.
    • Remove the four 4mm screws located around the battery.
  5. Acer Iconia A100 Battery Replacement: paso 5, imagen 1 de 2 Acer Iconia A100 Battery Replacement: paso 5, imagen 2 de 2
    • Use the tip of a plastic spudger or opening tool to gently push the connector head out of its socket.
    • Use your fingers or the flat edge of a plastic opening tool to lift the battery up and off of the device.
    • Be sure to not have any water around the device while removing the battery.
    • Be sure to be cautious while removing the battery and remove carefully; avoid ripping the wires attached to the battery.
Conclusión
2 personas más completaron esta guía.
Omar Acosta
Miembro Desde 03/03/15
526 Reputación
3 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 4
Ultimos 30 días: 14
Todo El Tiempo: 1,837
