Saltar al contenido principal
Acer Iconia A1-810 Screen Replacement
Qué necesitas
  1. Acer Iconia A1-810 Screen Replacement, Battery: paso 1, imagen 1 de 1
    • Remove the back cover by lifting with a plastic opening tool, below the camera button slot.
  2. Acer Iconia A1-810 Screen Replacement: paso 2, imagen 1 de 1
    • Remove the black tape connecting the battery to the motherboard.
  3. Acer Iconia A1-810 Screen Replacement: paso 3, imagen 1 de 1
    • Pinch the sides of the white resistor to safely remove it without damaging it or yourself.
  4. Acer Iconia A1-810 Screen Replacement: paso 4, imagen 1 de 2 Acer Iconia A1-810 Screen Replacement: paso 4, imagen 2 de 2
    • Remove battery from adhesive.
  5. Acer Iconia A1-810 Screen Replacement, Motherboard: paso 5, imagen 1 de 1
    • Use a Phillips #000 screwdriver to remove the screws around the perimeter of the motherboard.
  6. Acer Iconia A1-810 Screen Replacement: paso 6, imagen 1 de 2 Acer Iconia A1-810 Screen Replacement: paso 6, imagen 2 de 2
    • Disconnect the resistor attached to the orange tab by sliding the tail out.
    • Pry open the orange tab near the top left corner.
  7. Acer Iconia A1-810 Screen Replacement: paso 7, imagen 1 de 3 Acer Iconia A1-810 Screen Replacement: paso 7, imagen 2 de 3 Acer Iconia A1-810 Screen Replacement: paso 7, imagen 3 de 3
    • Disconnect all cords, wires, and resistors from the motherboard using tweezers.
  8. Acer Iconia A1-810 Screen Replacement: paso 8, imagen 1 de 3 Acer Iconia A1-810 Screen Replacement: paso 8, imagen 2 de 3 Acer Iconia A1-810 Screen Replacement: paso 8, imagen 3 de 3
    • Continue to disconnect all resistors attached from the motherboard, using tweezers.
  9. Acer Iconia A1-810 Screen Replacement: paso 9, imagen 1 de 1
    • Gently lift motherboard out.
    • The edges may be sharp.
  10. Acer Iconia A1-810 Screen Replacement, Screen: paso 10, imagen 1 de 3 Acer Iconia A1-810 Screen Replacement, Screen: paso 10, imagen 2 de 3 Acer Iconia A1-810 Screen Replacement, Screen: paso 10, imagen 3 de 3
    • Lift the three copper foils from the plate.
  11. Acer Iconia A1-810 Screen Replacement: paso 11, imagen 1 de 1
    • Add strips of tape to the sides of the device.
  12. Acer Iconia A1-810 Screen Replacement: paso 12, imagen 1 de 2 Acer Iconia A1-810 Screen Replacement: paso 12, imagen 2 de 2
    • Wedge the Jimmy between the screen and body of the device and ease around the whole edge of the device.
    • A reasonable amount of force is necessary to wedge deep into the screen.
    • The screen will possibly crack more and the debris will be scattered.
  13. Acer Iconia A1-810 Screen Replacement: paso 13, imagen 1 de 3 Acer Iconia A1-810 Screen Replacement: paso 13, imagen 2 de 3 Acer Iconia A1-810 Screen Replacement: paso 13, imagen 3 de 3
    • While holding the side of the screen, press the metal plates behind the device to pop the screen out.
Conclusión
15 personas más completaron esta guía.
John
Miembro Desde 01/29/15
635 Reputación
3 Guías creadas
Equipo
UWT Liner: Group 3 Miembro de UWT Liner: Group 3
Community
5 Miembros
3 Guías creadas
Un comentario
Before starting to remove the screen, remove the strip of black tape stuck over the screen ribbon cable (right hand end in the last picture) carefully lift the connector lock on the old screen connector and remove the ribbon cable completely.
Fit this ribbon cable to the new display before fitting the screen and the feed it through the slot provided as you install.
Michael - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 8
Ultimos 30 días: 20
Todo El Tiempo: 10,209
