Saltar al contenido principal
Acer Iconia A1-810 Motherboard Replacement
Qué necesitas
  1. Acer Iconia A1-810 Motherboard Replacement, Battery: paso 1, imagen 1 de 1
    • Remove the back cover by lifting with a plastic opening tool, below the camera button slot.
  2. Acer Iconia A1-810 Motherboard Replacement: paso 2, imagen 1 de 1
    • Remove the black tape connecting the battery to the motherboard.
  3. Acer Iconia A1-810 Motherboard Replacement: paso 3, imagen 1 de 1
    • Pinch the sides of the white resistor to safely remove it without damaging it or yourself.
  4. Acer Iconia A1-810 Motherboard Replacement: paso 4, imagen 1 de 2 Acer Iconia A1-810 Motherboard Replacement: paso 4, imagen 2 de 2
    • Remove battery from adhesive.
  5. Acer Iconia A1-810 Motherboard Replacement, Motherboard: paso 5, imagen 1 de 1
    • Use a Phillips #000 screwdriver to remove the screws around the perimeter of the motherboard.
  6. Acer Iconia A1-810 Motherboard Replacement: paso 6, imagen 1 de 2 Acer Iconia A1-810 Motherboard Replacement: paso 6, imagen 2 de 2
    • Disconnect the resistor attached to the orange tab by sliding the tail out.
    • Pry open the orange tab near the top left corner.
  7. Acer Iconia A1-810 Motherboard Replacement: paso 7, imagen 1 de 3 Acer Iconia A1-810 Motherboard Replacement: paso 7, imagen 2 de 3 Acer Iconia A1-810 Motherboard Replacement: paso 7, imagen 3 de 3
    • Disconnect all cords, wires, and resistors from the motherboard using tweezers.
  8. Acer Iconia A1-810 Motherboard Replacement: paso 8, imagen 1 de 3 Acer Iconia A1-810 Motherboard Replacement: paso 8, imagen 2 de 3 Acer Iconia A1-810 Motherboard Replacement: paso 8, imagen 3 de 3
    • Continue to disconnect all resistors attached from the motherboard, using tweezers.
  9. Acer Iconia A1-810 Motherboard Replacement: paso 9, imagen 1 de 1
    • Gently lift motherboard out.
    • The edges may be sharp.
Conclusión
7 personas más completaron esta guía.
John
Miembro Desde 01/29/15
635 Reputación
3 Guías creadas
Equipo
UWT Liner: Group 3 Miembro de UWT Liner: Group 3
Community
5 Miembros
3 Guías creadas
8 comentarios
I need main ic part num A1-810 iconia I need main ic
mehwish - Contestar
It was damage because high voltage
mehwish - Contestar
Can you replace the mini USB charger port without replacing entire motherboard and losing data?
theblackfox2 - Contestar
Hi there i need acer lconia A3 main bord how much it will cost me ?
Muhammad - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 5
Ultimos 30 días: 14
Todo El Tiempo: 5,353
