Saltar al contenido principal
Acer E5-571-54FL TrackPad Replacement
Qué necesitas
  1. Acer E5-571-54FL TrackPad Replacement, Battery: paso 1, imagen 1 de 1
    • Power down the laptop prior to beginning.
    • Turn the laptop over with the battery closest to your body.
  2. Acer E5-571-54FL TrackPad Replacement: paso 2, imagen 1 de 2 Acer E5-571-54FL TrackPad Replacement: paso 2, imagen 2 de 2
    • Insert the pointed end of a spudger into the battery release.
    • Slide the release gently all the way to the left.
    • You should hear a sound after the slide is all the way left. This lets you know the battery has disengaged.
  3. Acer E5-571-54FL TrackPad Replacement: paso 3, imagen 1 de 2 Acer E5-571-54FL TrackPad Replacement: paso 3, imagen 2 de 2
    • Place your hands on each end of the battery.
    • Pull the battery towards your body to remove it.
  4. Acer E5-571-54FL TrackPad Replacement, Keyboard: paso 4, imagen 1 de 1
    • Using a #0 Phillips screwdriver, remove a total of eighteen identical 8mm Phillips screws and set them aside.
  5. Acer E5-571-54FL TrackPad Replacement: paso 5, imagen 1 de 1
    • Rotate the laptop 180 degrees so that the battery compartment is now furthest away from your body.
  6. Acer E5-571-54FL TrackPad Replacement: paso 6, imagen 1 de 1
    • Turn the laptop over so that you can easily open the screen to a vertical position.
  7. Acer E5-571-54FL TrackPad Replacement: paso 7, imagen 1 de 1
    • Put your fingers under the top of the keyboard assembly directly below the Acer logo.
    • Carefully pull up on the center until you hear the tabs disengage from the bottom.
  8. Acer E5-571-54FL TrackPad Replacement: paso 8, imagen 1 de 3 Acer E5-571-54FL TrackPad Replacement: paso 8, imagen 2 de 3 Acer E5-571-54FL TrackPad Replacement: paso 8, imagen 3 de 3
    • Work your way around the seam with the plastic opening tool carefully prying the base and top cover apart.
    • If you have difficulty with the plastic opening tool, use a metal spudger but be more cautious to not damage or mar your laptop case.
  9. Acer E5-571-54FL TrackPad Replacement: paso 9, imagen 1 de 1
    • When the two halves are separated, carefully lift up the front of the keyboard and touchpad assembly.
    • You will see three ribbon cables attached to the motherboard.
  10. Acer E5-571-54FL TrackPad Replacement: paso 10, imagen 1 de 3 Acer E5-571-54FL TrackPad Replacement: paso 10, imagen 2 de 3 Acer E5-571-54FL TrackPad Replacement: paso 10, imagen 3 de 3
    • Closest to the ribbon cable on the zero insertion force (ZIF) connector is a white locking tab.
    • Carefully lift up on the locking tab with the plastic opening tool to release the ribbon cable. (Picture 2)
    • Remove the ribbon cable from the connector.
  11. Acer E5-571-54FL TrackPad Replacement: paso 11, imagen 1 de 3 Acer E5-571-54FL TrackPad Replacement: paso 11, imagen 2 de 3 Acer E5-571-54FL TrackPad Replacement: paso 11, imagen 3 de 3
    • Closest to the ribbon cable on the ZIF connector is a black locking tab.
  12. Acer E5-571-54FL TrackPad Replacement: paso 12, imagen 1 de 3 Acer E5-571-54FL TrackPad Replacement: paso 12, imagen 2 de 3 Acer E5-571-54FL TrackPad Replacement: paso 12, imagen 3 de 3
    • On each side of the large connector there are two white tabs.
    • Carefully push away from you with the plastic opening tool on each white tab to release the cable. (Picture 2)
  13. Acer E5-571-54FL TrackPad Replacement: paso 13, imagen 1 de 3 Acer E5-571-54FL TrackPad Replacement: paso 13, imagen 2 de 3 Acer E5-571-54FL TrackPad Replacement: paso 13, imagen 3 de 3
    • Once all three ribbon cables are disconnected, lift off the top cover with the keyboard and touchpad.
  14. Acer E5-571-54FL TrackPad Replacement, TrackPad: paso 14, imagen 1 de 1
    • Remove the screw at the bottom of the track pad using the Phillips #0 screwdriver.
  15. Acer E5-571-54FL TrackPad Replacement: paso 15, imagen 1 de 2 Acer E5-571-54FL TrackPad Replacement: paso 15, imagen 2 de 2
    • Gently remove the copper adhesive strips attached to the track pad.
    • Remove the two screws using the Phillips #0 screwdriver.
  16. Acer E5-571-54FL TrackPad Replacement: paso 16, imagen 1 de 2 Acer E5-571-54FL TrackPad Replacement: paso 16, imagen 2 de 2
    • Pop the track pad out of of the keyboard casing and remove it from the device.
Conclusión
Jennifer Hancock
Miembro Desde 09/19/19
325 Reputación
3 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 18
Todo El Tiempo: 418
