Introducción
The motherboard is like the central nervous system of your computer. If you have issues with your hardware, a faulty motherboard or a loose connection may be the problem.
Qué necesitas
Power down the laptop prior to beginning.
Turn the laptop over with the battery closest to your body.
Using a #0 Phillips screwdriver, remove a total of eighteen identical 8mm Phillips screws and set them aside.
Locate the Wi-Fi card. It is just below the fan and has a white coaxial cable and a black coaxial cable attached to it.
Grab the section of the white coaxial cable behind the brass connection using ESD safe blunt nose metal tweezers.
Carefully lift the white and black coaxial cables up and forward to disconnect the them from the Wi-Fi card.
Locate the CPU cooling fan in the upper left corner of the laptop.
Using a Phillips #0 screwdriver, remove the two 4.5 mm screws that secure the fan to the case.
Place the tips of the ESD safe pointed tweezers between the plug and the socket of the fan connection.
Gently push the tweezers to the left to disconnect the fan plug.
Move the fan connector and its wires to free them from the motherboard and the Wi-Fi card.
Locate the hard drive and its carriage at the lower right corner of the laptop.
Release the USB port ribbon cable by using the plastic opening tool to carefully lift up the black locking tab of the ZIF connector.
Move the USB port ribbon cable to the side.
Hold the hard drive carriage with your non-dominant hand along one side. Ensure one of the Phillips screws is visible.
Using a Phillips #0 screwdriver, remove the 3 mm screw to release the side of the hard drive from the carriage.
Repeat the previous bullet to remove the second 3 mm Phillips #0 screw.
Place the tips of the ESD safe pointed tweezers between the plug and the socket of the speaker connection.
Gently push left to disconnect the speaker plug.
Carefully lift up on the right edge of the motherboard near the hard drive connector.
With minimal force, pull the motherboard to the right freeing the ports on the left from the case.
Put down the right side and allow the motherboard to rest in the case.
Lift the left side of the motherboard up and turn it over so the ports are now facing right.
3 personas más completaron esta guía.
Un comentario
Hi is this the DDR4 with Geforce MX Series Vcard variant or the older DDR3?
