Saltar al contenido principal
Acer Chromebook Spin 15 CP315-1H-P1K8 Microphone Replacement
Qué necesitas
  1. Acer Chromebook Spin 15 CP315-1H-P1K8 Microphone Replacement, Back Cover: paso 1, imagen 1 de 2 Acer Chromebook Spin 15 CP315-1H-P1K8 Microphone Replacement, Back Cover: paso 1, imagen 2 de 2
    • Make sure the device is fully powered off.
    • Flip the computer over so that the back is facing up.
    • Remove the twelve 6mm Phillips #1 screws from the bottom of the laptop.
  2. Acer Chromebook Spin 15 CP315-1H-P1K8 Microphone Replacement: paso 2, imagen 1 de 3 Acer Chromebook Spin 15 CP315-1H-P1K8 Microphone Replacement: paso 2, imagen 2 de 3 Acer Chromebook Spin 15 CP315-1H-P1K8 Microphone Replacement: paso 2, imagen 3 de 3
    • Use the iFixit opening tools as wedges to pry the back of the laptop off.
    • Go slow, making sure not to snap the plastic. With enough of a gap made, you can use your hand to finish taking off the back.
  3. Acer Chromebook Spin 15 CP315-1H-P1K8 Microphone Replacement, Display Screen: paso 3, imagen 1 de 2 Acer Chromebook Spin 15 CP315-1H-P1K8 Microphone Replacement, Display Screen: paso 3, imagen 2 de 2
    • Remove the five 6mm Phillips #1 screws from the hinges on either side of the laptop.
  4. Acer Chromebook Spin 15 CP315-1H-P1K8 Microphone Replacement: paso 4, imagen 1 de 3 Acer Chromebook Spin 15 CP315-1H-P1K8 Microphone Replacement: paso 4, imagen 2 de 3 Acer Chromebook Spin 15 CP315-1H-P1K8 Microphone Replacement: paso 4, imagen 3 de 3
    • Unplug the camera/microphone ribbon cable from the circuit board.
    • Remove the single 3mm Phillips #1 screw from the Intel core.
    • Unplug the cable from the circuit board.
  5. Acer Chromebook Spin 15 CP315-1H-P1K8 Microphone Replacement: paso 5, imagen 1 de 3 Acer Chromebook Spin 15 CP315-1H-P1K8 Microphone Replacement: paso 5, imagen 2 de 3 Acer Chromebook Spin 15 CP315-1H-P1K8 Microphone Replacement: paso 5, imagen 3 de 3
    • Use the plastic opening tool, create a gap between the back and front of the display.
    • Lift the front out with your hands.
  6. Acer Chromebook Spin 15 CP315-1H-P1K8 Microphone Replacement, Microphone: paso 6, imagen 1 de 1
    • Remove the two 3 mm Phillips #1 black screws from the microphone at the top of the display cover.
  7. Acer Chromebook Spin 15 CP315-1H-P1K8 Microphone Replacement: paso 7, imagen 1 de 2 Acer Chromebook Spin 15 CP315-1H-P1K8 Microphone Replacement: paso 7, imagen 2 de 2
    • Remove the microphone component from the rest of the computer by detaching the connected wire.
    • The camera component of the laptop is connected to the same wire, so remove this as well.
    • The camera is only held down with adhesives, so there is no need to use any tools.
  8. Acer Chromebook Spin 15 CP315-1H-P1K8 Microphone Replacement: paso 8, imagen 1 de 2 Acer Chromebook Spin 15 CP315-1H-P1K8 Microphone Replacement: paso 8, imagen 2 de 2
    • Remove the microphone and camera wire out from around the display screen.
    • Remove the ribbon cable at the bottom of the display screen to completely free the wire.
    • Carefully remove the adhesive tape and take out the ribbon cable.
  9. Acer Chromebook Spin 15 CP315-1H-P1K8 Microphone Replacement: paso 9, imagen 1 de 2 Acer Chromebook Spin 15 CP315-1H-P1K8 Microphone Replacement: paso 9, imagen 2 de 2
    • Remove the microphone from the laptop.
Conclusión
Ian Sullivan
Miembro Desde 10/29/19
116 Reputación
1 Guía escrita
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 12
Todo El Tiempo: 635
