Saltar al contenido principal
Acer Chromebook Spin 15 CP315-1H-P1K8 Battery Replacement
Qué necesitas
  1. Acer Chromebook Spin 15 CP315-1H-P1K8 Battery Replacement, Back Cover: paso 1, imagen 1 de 2 Acer Chromebook Spin 15 CP315-1H-P1K8 Battery Replacement, Back Cover: paso 1, imagen 2 de 2
    • Make sure the device is fully powered off.
    • Flip the computer over so that the back is facing up.
    • Remove the twelve 6mm Phillips #1 screws from the bottom of the laptop.
  2. Acer Chromebook Spin 15 CP315-1H-P1K8 Battery Replacement: paso 2, imagen 1 de 3 Acer Chromebook Spin 15 CP315-1H-P1K8 Battery Replacement: paso 2, imagen 2 de 3 Acer Chromebook Spin 15 CP315-1H-P1K8 Battery Replacement: paso 2, imagen 3 de 3
    • Use the iFixit opening tools as wedges to pry the back of the laptop off.
    • Go slow, making sure not to snap the plastic. With enough of a gap made, you can use your hand to finish taking off the back.
  3. Acer Chromebook Spin 15 CP315-1H-P1K8 Battery Replacement, Battery: paso 3, imagen 1 de 3 Acer Chromebook Spin 15 CP315-1H-P1K8 Battery Replacement, Battery: paso 3, imagen 2 de 3 Acer Chromebook Spin 15 CP315-1H-P1K8 Battery Replacement, Battery: paso 3, imagen 3 de 3
    • Remove the ribbon cable by pulling the plastic connector that is connected to the motherboard out.
  4. Acer Chromebook Spin 15 CP315-1H-P1K8 Battery Replacement: paso 4, imagen 1 de 1
    • Remove the battery from the laptop by hand.
Conclusión
Evan Costa
Miembro Desde 10/29/19
503 Reputación
3 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 5
Ultimos 30 días: 27
Todo El Tiempo: 2,618
