Saltar al contenido principal
Acer Chromebook R11 Wireless Card Replacement
Qué necesitas
  1. Acer Chromebook R11 Wireless Card Replacement, Wireless Card: paso 1, imagen 1 de 1
    • Remove eleven 7.23mm Phillips #1 screws from the back panel.
    • Using a spudger, carefully separate back panel from main body.
    • The back panel is still attached to the main body by a ribbon cable. Use care not to damage the cable.
  2. Acer Chromebook R11 Wireless Card Replacement: paso 2, imagen 1 de 1
    • Disconnect the two antenna cables (one black and one white) that are attached to the wireless card.
    • Note the position of the black and white antenna cables on the card.
  3. Acer Chromebook R11 Wireless Card Replacement: paso 3, imagen 1 de 1
    • Remove the single 2.85 mm Phillips #1 screw that secures the wireless card.
  4. Acer Chromebook R11 Wireless Card Replacement: paso 4, imagen 1 de 1
    • Carefully slide the wireless card out of its socket on the motherboard.
Conclusión
3 personas más completaron esta guía.
Sean Harter
Miembro Desde 02/15/17
146 Reputación
1 Guía escrita
Equipo
USF Tampa, Team 1-2, Kass Spring 2017 Miembro de USF Tampa, Team 1-2, Kass Spring 2017
USFT-KASS-S17S1G2
4 Miembros
6 Guías creadas
6 comentarios
I think you are confusing a WiFi module and a CPU...
Miles Raymond - Contestar
Sorry, incorrect. The cpu is on the mother board, not connected by slots. You may also notice the small brass connecteros on the left side of the wireless card. Those are u.fl connectors used for the wifi antennas. CPUs never ever have these
T R -
I need some help. My chromebook has a 2.4ghz processor but I want to upgrade it to a 5ghz. Is this what I should follow to do that? does it take an AC processor or only N? Will it be compatible if my processor is a broadcom and I want to upgrade to intel? Please let me know as soon as possible because my chroembook is really slow even though it comes with 32gb instead of 2gb.
John Jacobs - Contestar
Hi, also have the R11 bluetooth glitch. I’d like to try and preserve warranty as in the CI so can’t easily send it back for repair.
Is this likely to work with any microPCIe card or does it have to be the exact unit specified, believe there are 5 GHz variants now which weren’t available when originally launched.
Andre De Guerin - Contestar
Hey there! I could use some help. The WiFi won’t turn on. This happened on my C720 as well. Does that mean the wireless card is damaged or is it a loose connection? I’m not to savy at these things. Both Chromebooks worked until I started having the wifi issues. I tried to reset the C720, reload the OS, neither didn’t work and it’s been sitting on the shelf the past couple of years. although I just turned it on today, same issue with the OS.
I bought the R11 as a replacement and it worked fine up until last week. It doesn’t recognize wi-fi and it the wi-fi tab keeps defaulting back to the off position. Any ideas about how to approach this?
Shirley Vretson - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 3
Ultimos 30 días: 14
Todo El Tiempo: 4,575
