Introducción
The speakers of a Chromebook can be removed fairly easily. The speakers themselves are not hidden, but several wires must be moved out of the way and the speakers' connection to the motherboard must be detached too.
The steps are straightforward, but wires should always be handled with caution, as they can be fragile.
Qué necesitas
Using a Phillips screwdriver, remove all eleven 7.0 mm screws from the bottom of the Chromebook.
Un comentario
Hi, do you know how to replace the microphone on this chromebook?
