Introducción
If the LED lights of your Acer Chromebook R11 CB5-132T-C1LK are not functioning properly, this guide will detail how to access and remove the LED board for replacement.
Qué necesitas
Using a Phillips screwdriver, remove all eleven 7.0 mm screws from the bottom of the Chromebook.
Use the flat end of the spudger to lift the retaining flap on the LED board ZIF connector.
Pull the ribbon cable from the ZIF connector using tweezers.
Casi Terminas!
Conclusión
