Saltar al contenido principal
Acer Chromebook R11 CB5-132T-C1LK Camera Replacement
Qué necesitas
  1. Acer Chromebook R11 CB5-132T-C1LK Camera Replacement, Camera: paso 1, imagen 1 de 2 Acer Chromebook R11 CB5-132T-C1LK Camera Replacement, Camera: paso 1, imagen 2 de 2
    • Insert the metal spudger into the groove on the edge of the screen.
    • Carefully slide the spudger from one corner to another.
    • When there is room for a finger, remove the screen by gently lifting it out of the computer.
  2. Acer Chromebook R11 CB5-132T-C1LK Camera Replacement: paso 2, imagen 1 de 1
    • Using a heavy duty spudger, lift the camera off the screen base.
    • The camera will be connected to the base with an adhesive.
  3. Acer Chromebook R11 CB5-132T-C1LK Camera Replacement: paso 3, imagen 1 de 1
    • Unplug the camera from its port.
Conclusión
Equipo
Cal Poly, Team S23-G2, Livingston Spring 2017 Miembro de Cal Poly, Team S23-G2, Livingston Spring 2017
CPSU-LIVINGSTON-S17S23G2
4 Miembros
12 Guías creadas
Un comentario
Hi Elizabeh, can you do a tutorial to change the mic on this chromebook?
There was a production batch of this chromebook that had a problem with the mic. So a lot of people could benefit from this.
Cheers!
Álvaro Guzmán Parrochia - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 2
Ultimos 30 días: 9
Todo El Tiempo: 523
