Saltar al contenido principal
Acer Chromebook R11 C738T-C44Z Wireless Card Replacement
Qué necesitas
  1. Acer Chromebook R11 C738T-C44Z Wireless Card Replacement, Back Cover: paso 1, imagen 1 de 3 Acer Chromebook R11 C738T-C44Z Wireless Card Replacement, Back Cover: paso 1, imagen 2 de 3 Acer Chromebook R11 C738T-C44Z Wireless Card Replacement, Back Cover: paso 1, imagen 3 de 3
    • Lay the laptop with the back side up.
    • Use a Phillips #1 screwdriver to remove eleven 3 mm screws.
    • Use the opening tool to pry the back cover off gently by placing it in the seam and working your way around the perimeter.
  2. Acer Chromebook R11 C738T-C44Z Wireless Card Replacement, Wireless Card: paso 2, imagen 1 de 2 Acer Chromebook R11 C738T-C44Z Wireless Card Replacement, Wireless Card: paso 2, imagen 2 de 2
    • Disconnect the two antenna cables (one black and one white) that are attached to the wireless card.
  3. Acer Chromebook R11 C738T-C44Z Wireless Card Replacement: paso 3, imagen 1 de 1
    • Use a Phillips #1 screwdriver to remove the single 3 mm screw that secures the wireless card.
  4. Acer Chromebook R11 C738T-C44Z Wireless Card Replacement: paso 4, imagen 1 de 2 Acer Chromebook R11 C738T-C44Z Wireless Card Replacement: paso 4, imagen 2 de 2
    • Carefully slide the wireless card out of its socket from the motherboard.
Conclusión
Equipo
Gateway, Team 1-4, Saknee Fall 2021 Miembro de Gateway, Team 1-4, Saknee Fall 2021
GCC-SAKNEE-F21S1G4
4 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 13
Todo El Tiempo: 344
