Saltar al contenido principal
Acer Chromebook R11 C738T-C44Z Speakers Replacement
Qué necesitas
  1. Acer Chromebook R11 C738T-C44Z Speakers Replacement, Back Cover: paso 1, imagen 1 de 3 Acer Chromebook R11 C738T-C44Z Speakers Replacement, Back Cover: paso 1, imagen 2 de 3 Acer Chromebook R11 C738T-C44Z Speakers Replacement, Back Cover: paso 1, imagen 3 de 3
    • Lay the laptop with the back side up.
    • Use a Phillips #1 screwdriver to remove eleven 3 mm screws.
    • Use the opening tool to pry the back cover off gently by placing it in the seam and working your way around the perimeter.
  2. Acer Chromebook R11 C738T-C44Z Speakers Replacement, Battery: paso 2, imagen 1 de 2 Acer Chromebook R11 C738T-C44Z Speakers Replacement, Battery: paso 2, imagen 2 de 2
    • Unplug the battery connector from the motherboard. (The motherboard is a group of wires in rainbow colors)
    • Use a Phillips #1 screwdriver to remove the two 3 mm screws, (one on each side of the battery), that secure it in place.
  3. Acer Chromebook R11 C738T-C44Z Speakers Replacement: paso 3, imagen 1 de 1
    • Remove battery from its holder by pulling it upwards from the device
    • Attempt to remove it as gently as possible to avoid damaging the Motherboard
  4. Acer Chromebook R11 C738T-C44Z Speakers Replacement: paso 4, imagen 1 de 1
    • Install the new battery and again use a Phillips #1 screwdriver to remove the two 3 mm screws
  5. Acer Chromebook R11 C738T-C44Z Speakers Replacement, Speakers: paso 5, imagen 1 de 2 Acer Chromebook R11 C738T-C44Z Speakers Replacement, Speakers: paso 5, imagen 2 de 2
    • Gently remove the LED Board Ribbon connected to the mother board.
  6. Acer Chromebook R11 C738T-C44Z Speakers Replacement: paso 6, imagen 1 de 3 Acer Chromebook R11 C738T-C44Z Speakers Replacement: paso 6, imagen 2 de 3 Acer Chromebook R11 C738T-C44Z Speakers Replacement: paso 6, imagen 3 de 3
    • Gently pry up speaker up using a spudger or opening tool to remove it.
    • It has an adhesive, so you might have to use some force.
    • Screwdrivers should not be used as prying tools and could cause damage to delicate components.
    • Repeat the same process for the other speaker.
  7. Acer Chromebook R11 C738T-C44Z Speakers Replacement: paso 7, imagen 1 de 3 Acer Chromebook R11 C738T-C44Z Speakers Replacement: paso 7, imagen 2 de 3 Acer Chromebook R11 C738T-C44Z Speakers Replacement: paso 7, imagen 3 de 3
    • Use the opening tool to unplug the speaker cable from the motherboard.
    • Disconnect the keyboard ribbon cable from the motherboard.
  8. Acer Chromebook R11 C738T-C44Z Speakers Replacement: paso 8, imagen 1 de 1
    • Using the opening tool to unlock and disconnect the touchpad cable.
  9. Acer Chromebook R11 C738T-C44Z Speakers Replacement: paso 9, imagen 1 de 3 Acer Chromebook R11 C738T-C44Z Speakers Replacement: paso 9, imagen 2 de 3 Acer Chromebook R11 C738T-C44Z Speakers Replacement: paso 9, imagen 3 de 3
    • Gently lift the speakers up and remove the cable from the system.
Conclusión
Una persona más ha completado esta guía.
Equipo
Gateway, Team 1-4, Saknee Fall 2021 Miembro de Gateway, Team 1-4, Saknee Fall 2021
GCC-SAKNEE-F21S1G4
4 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 6
Todo El Tiempo: 121
