Saltar al contenido principal
Acer Chromebook CB5-571-C5XU Trackpad Replacement
Qué necesitas
  1. Acer Chromebook CB5-571-C5XU Trackpad Replacement, Bottom Case: paso 1, imagen 1 de 2 Acer Chromebook CB5-571-C5XU Trackpad Replacement, Bottom Case: paso 1, imagen 2 de 2
    • Remove the following eighteen screws using a Phillips #0 screwdriver.
    • Make sure the Chromebook is unplugged and shut down, so no files are lost and there is no risk of electrocution.
  2. Acer Chromebook CB5-571-C5XU Trackpad Replacement: paso 2, imagen 1 de 2 Acer Chromebook CB5-571-C5XU Trackpad Replacement: paso 2, imagen 2 de 2
    • Using the flat side of the spudger, pry open the bottom case of the laptop.
    • Working from the front to the back, where it connects to the screen, proved to be the easiest way of popping the case off.
  3. Acer Chromebook CB5-571-C5XU Trackpad Replacement, Battery: paso 3, imagen 1 de 1
    • Using a Phillips #0 screwdriver, unscrew the screw on right side of the battery placement.
    • Be careful not to lose the screw and have a small container nearby to place it in.
  4. Acer Chromebook CB5-571-C5XU Trackpad Replacement: paso 4, imagen 1 de 1
    • Using a plastic opening tool, disconnect the wires connecting the battery to the motherboard.
  5. Acer Chromebook CB5-571-C5XU Trackpad Replacement: paso 5, imagen 1 de 1
    • Gently lift the battery out and remove it from the laptop casing.
  6. Acer Chromebook CB5-571-C5XU Trackpad Replacement, Trackpad: paso 6, imagen 1 de 1
    • Unhook the black ribbon from the motherboard, using the opening tool to pull the hooks in the direction of the arrows.
    • Once the hooks are released, simply pull the black ribbon outward to remove it from the motherboard.
  7. Acer Chromebook CB5-571-C5XU Trackpad Replacement: paso 7, imagen 1 de 3 Acer Chromebook CB5-571-C5XU Trackpad Replacement: paso 7, imagen 2 de 3 Acer Chromebook CB5-571-C5XU Trackpad Replacement: paso 7, imagen 3 de 3
    • Using a Phillips #0 screwdriver, remove the 7 screws holding the trackpad in place.
    • The metal piece at the bottom edge of the laptop will lift off after the screws are removed.
  8. Acer Chromebook CB5-571-C5XU Trackpad Replacement: paso 8, imagen 1 de 1
    • Use the spudger tool to unhook the locks on both sides of the end of the white ribbon. Pull the ribbon outward away from the motherboard.
  9. Acer Chromebook CB5-571-C5XU Trackpad Replacement: paso 9, imagen 1 de 2 Acer Chromebook CB5-571-C5XU Trackpad Replacement: paso 9, imagen 2 de 2
    • Use the spudger tool to pry the trackpad up and away from the laptop.
Conclusión
David Flint
Miembro Desde 10/17/17
273 Reputación
2 Guías creadas
Equipo
2 comentarios
How do I remove the touchpad from the backing/bracket? The replacement touchpad I bought has none of the metal bracket, and I believe I need to remove it from my old broken one.
Shawn H - Contestar
For the record I ended up having to purchase a new mounting bracket separately and affix it ($5). Hope this helps someone. I’ve done the repair but the trackpad is still not functioning. Not sure what the issue is but the swap was pretty easy.
Shawn H - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 5
Ultimos 30 días: 8
Todo El Tiempo: 326
