Saltar al contenido principal
Acer Chromebook CB5-571-C5XU Battery Replacement
Qué necesitas
  1. Acer Chromebook CB5-571-C5XU Battery Replacement, Bottom Case: paso 1, imagen 1 de 2 Acer Chromebook CB5-571-C5XU Battery Replacement, Bottom Case: paso 1, imagen 2 de 2
    • Remove the following eighteen screws using a Phillips #0 screwdriver.
    • Make sure the Chromebook is unplugged and shut down, so no files are lost and there is no risk of electrocution.
  2. Acer Chromebook CB5-571-C5XU Battery Replacement: paso 2, imagen 1 de 2 Acer Chromebook CB5-571-C5XU Battery Replacement: paso 2, imagen 2 de 2
    • Using the flat side of the spudger, pry open the bottom case of the laptop.
    • Working from the front to the back, where it connects to the screen, proved to be the easiest way of popping the case off.
  3. Acer Chromebook CB5-571-C5XU Battery Replacement, Battery: paso 3, imagen 1 de 1
    • Using a Phillips #0 screwdriver, unscrew the screw on right side of the battery placement.
    • Be careful not to lose the screw and have a small container nearby to place it in.
  4. Acer Chromebook CB5-571-C5XU Battery Replacement: paso 4, imagen 1 de 1
    • Using a plastic opening tool, disconnect the wires connecting the battery to the motherboard.
  5. Acer Chromebook CB5-571-C5XU Battery Replacement: paso 5, imagen 1 de 1
    • Gently lift the battery out and remove it from the laptop casing.
Conclusión
To reassemble your device, follow these guidelines in reverse order.
3 personas más completaron esta guía.
Kenneth Bowers
Miembro Desde 04/08/16
1,381 Reputación
7 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 9
Todo El Tiempo: 812
