Saltar al contenido principal
Acer Chromebook CB3-431-C5EX Wireless Card Replacement
Qué necesitas
  1. Acer Chromebook CB3-431-C5EX Wireless Card Replacement, Bottom Panel: paso 1, imagen 1 de 1
    • Working on your device while it is turned on may result in electric shock. Make sure to shut down and unplug your device before you begin.
    • Turn device over so the bottom panel is facing you.
  2. Acer Chromebook CB3-431-C5EX Wireless Card Replacement: paso 2, imagen 1 de 1
    • Remove the eight 4mm Phillips #0 screws.
    • Remove the two 6mm Phillips #0 screws.
  3. Acer Chromebook CB3-431-C5EX Wireless Card Replacement: paso 3, imagen 1 de 2 Acer Chromebook CB3-431-C5EX Wireless Card Replacement: paso 3, imagen 2 de 2
    • Insert a plastic opening tool into the crack between the bottom panel and the side of the computer.
    • Gently pry the panel off the computer by continuously pulling up and on the panel and moving the plastic opening tool around the crack until the panel comes off.
    • There are several clips holding the cover in place.
    • Remove the bottom panel and set it aside.
  4. Acer Chromebook CB3-431-C5EX Wireless Card Replacement, Wireless Card: paso 4, imagen 1 de 1
    • Remove the 4mm Phillips #0 screw securing the wireless adapter to the main circuit board.
  5. Acer Chromebook CB3-431-C5EX Wireless Card Replacement: paso 5, imagen 1 de 1
    • Unplug the Wireless adapter from the main circuit board by giving the adapter light pressure and sliding it out of its port.
  6. Acer Chromebook CB3-431-C5EX Wireless Card Replacement: paso 6, imagen 1 de 1
    • Detach the two cables from the Adapter by pulling directly up on them, and then remove the adapter.
    • Note that the black cable is already detached in this photo to show what it looks like with the cables removed.
    • Be sure to note the original locations of the black and white cables when installing the new wireless adapter.
Conclusión
3 personas más completaron esta guía.
Holden Kurfess
Miembro Desde 04/18/17
358 Reputación
1 Guía escrita
Equipo
Cal Poly, Team S17-G3, Banghart Spring 2017 Miembro de Cal Poly, Team S17-G3, Banghart Spring 2017
CPSU-BANGHART-S17S17G3
5 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 11
Todo El Tiempo: 1,463
