Saltar al contenido principal
Acer Chromebook CB3-131-C3KD Keyboard Key Replacement
Qué necesitas
  1. Acer Chromebook CB3-131-C3KD Keyboard Key Replacement, Keyboard Key: paso 1, imagen 1 de 2 Acer Chromebook CB3-131-C3KD Keyboard Key Replacement, Keyboard Key: paso 1, imagen 2 de 2
    • Make sure you turn off the laptop before starting.
    • Place the flat head screw driver under the key, but over the key clip retainer.
  2. Acer Chromebook CB3-131-C3KD Keyboard Key Replacement: paso 2, imagen 1 de 1
    • Push down on one of the bottom corners of the key, so that the opposite diagonal corner rises and gives leeway.
    • Carefully place the flat head screw driver under the raised corner.
    • Carefully pry up from underneath the raised corner to raise the metal clips away from the key base.
  3. Acer Chromebook CB3-131-C3KD Keyboard Key Replacement: paso 3, imagen 1 de 2 Acer Chromebook CB3-131-C3KD Keyboard Key Replacement: paso 3, imagen 2 de 2
    • Pry up from the top left and right corners of the retainer subsequently.
    • Remove clip retainer.
Conclusión
Johnathan
Miembro Desde 09/26/17
216 Reputación
2 Guías creadas
Equipo
USF Tampa, Team S11-G1, Passmore Fall 2017 Miembro de USF Tampa, Team S11-G1, Passmore Fall 2017
USFT-PASSMORE-F17S11G1
3 Miembros
10 Guías creadas
Un comentario
I mean… That’s half of the replacement… so there’s that.
Darren D. MacDonald - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 9
Ultimos 30 días: 15
Todo El Tiempo: 1,454
