Saltar al contenido principal
Acer Chromebook CB3-111-C8UB Screen Replacement
Qué necesitas
  1. Acer Chromebook CB3-111-C8UB Screen Replacement, Screen: paso 1, imagen 1 de 2 Acer Chromebook CB3-111-C8UB Screen Replacement, Screen: paso 1, imagen 2 de 2
    • Insert the plastic opening tool into the slit on the outer edge of the laptop's screen to remove the plastic piece that borders the screen. Work the plastic opening tool all the way around the screen until the plastic cover has been removed.
    • The plastic is flexible, so don't be afraid to use some force.
  2. Acer Chromebook CB3-111-C8UB Screen Replacement: paso 2, imagen 1 de 1
    • Locate and remove the four 4.2mm screws holding the screen in place by using a Phillips #1 screwdriver.
  3. Acer Chromebook CB3-111-C8UB Screen Replacement: paso 3, imagen 1 de 3 Acer Chromebook CB3-111-C8UB Screen Replacement: paso 3, imagen 2 de 3 Acer Chromebook CB3-111-C8UB Screen Replacement: paso 3, imagen 3 de 3
    • Pull away the screen from the plastic backing. Lay the screen face down onto the keyboard.
    • Use tweezers to peel of the sticker securing the cable to the laptop behind the screen.
    • Unplug the cable to separate the screen.
Conclusión
Una persona más ha completado esta guía.
Equipo
Cal Poly, Team 22-7, Maness Winter 2017 Miembro de Cal Poly, Team 22-7, Maness Winter 2017
CPSU-MANESS-W17S22G7
4 Miembros
12 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 3
Todo El Tiempo: 797
