Saltar al contenido principal
Acer Chromebook CB3-111-C8UB Audio Jack Replacement
Qué necesitas
  1. Acer Chromebook CB3-111-C8UB Audio Jack Replacement, Back Panel Removal: paso 1, imagen 1 de 2 Acer Chromebook CB3-111-C8UB Audio Jack Replacement, Back Panel Removal: paso 1, imagen 2 de 2
    • Position the laptop upside down with the hinges on the side furthest away from you.
    • Remove the eight 8mm screws with a phillips #1 screwdriver,
    • Remove the four 4.5mm screws with a phillips #1 screwdriver,
  2. Acer Chromebook CB3-111-C8UB Audio Jack Replacement: paso 2, imagen 1 de 3 Acer Chromebook CB3-111-C8UB Audio Jack Replacement: paso 2, imagen 2 de 3 Acer Chromebook CB3-111-C8UB Audio Jack Replacement: paso 2, imagen 3 de 3
    • There is a wire connecting the two pieces of the laptop, from the inside, on the left, be careful not to damage it.
    • Use the plastic opening tool to pry open then remove the plastic base from the rest of the laptop. Start from the right side and work towards the left.
    • Set the plastic base beside the laptop by opening it as if you were opening a book.
  3. Acer Chromebook CB3-111-C8UB Audio Jack Replacement: paso 3, imagen 1 de 2 Acer Chromebook CB3-111-C8UB Audio Jack Replacement: paso 3, imagen 2 de 2
    • Flip up the small white ZIF connector by using a fingernail or metal spudger.
    • Pull the blue tab to remove the ribbon cable.
    • The ribbon cable is adhered to the plastic so it will take a little bit of force to remove it.
  4. Acer Chromebook CB3-111-C8UB Audio Jack Replacement, Audio Jack: paso 4, imagen 1 de 2 Acer Chromebook CB3-111-C8UB Audio Jack Replacement, Audio Jack: paso 4, imagen 2 de 2
    • Remove the three 4.5mm screws using a phillips #1 screwdriver.
    • Now remove the chip.
Conclusión
Ryan Locatelli
Miembro Desde 01/27/17
161 Reputación
1 Guía escrita
Equipo
Cal Poly, Team 22-7, Maness Winter 2017 Miembro de Cal Poly, Team 22-7, Maness Winter 2017
CPSU-MANESS-W17S22G7
4 Miembros
12 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 4
Todo El Tiempo: 904
