Saltar al contenido principal
Acer Chromebook CB3-111-C670 Screen Replacement
Qué necesitas
  1. Acer Chromebook CB3-111-C670 Screen Replacement, Screen: paso 1, imagen 1 de 2 Acer Chromebook CB3-111-C670 Screen Replacement, Screen: paso 1, imagen 2 de 2
    • Unplug and power off the laptop before starting this repair.
    • Pry the white frame away from the screen with an opening tool.
    • As you move the spudger along the seam between the frame and the screen, the clips holding the frame in place will loosen.
  2. Acer Chromebook CB3-111-C670 Screen Replacement: paso 2, imagen 1 de 2 Acer Chromebook CB3-111-C670 Screen Replacement: paso 2, imagen 2 de 2
    • Remove the four screws within the silver brackets that are holding the screen to the back of the laptop.
  3. Acer Chromebook CB3-111-C670 Screen Replacement: paso 3, imagen 1 de 1
    • Once you've removed the screws, lift the piece of tape that is covering the display connector.
    • Use a spudger to flip up the black tab on top of the connector to unlock the ZIF connector.
  4. Acer Chromebook CB3-111-C670 Screen Replacement: paso 4, imagen 1 de 1
    • Pull the ribbon cable out with tweezers and remove the screen.
Conclusión
9 personas más completaron esta guía.
Allen Lewis
Miembro Desde 01/20/16
259 Reputación
1 Guía escrita
Equipo
USF Tampa, Team 10-5, Remmell Spring 2016 Miembro de USF Tampa, Team 10-5, Remmell Spring 2016
USFT-REMMELL-S16S10G5
3 Miembros
8 Guías creadas
Un comentario
Very easy. Thanks
johnqm123 - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 10
Todo El Tiempo: 4,973
