Saltar al contenido principal
Acer Chromebook C740-C4PE Touchpad Replacement
Qué necesitas
  1. Acer Chromebook C740-C4PE Touchpad Replacement, Battery: paso 1, imagen 1 de 3 Acer Chromebook C740-C4PE Touchpad Replacement, Battery: paso 1, imagen 2 de 3 Acer Chromebook C740-C4PE Touchpad Replacement, Battery: paso 1, imagen 3 de 3
    • Make sure the laptop is turned off and unplugged before starting.
    • Unscrew the thirteen 10mm screws on the back of the computer using the Phillips #0 screwdriver.
    • Using the spudger or other prying tool, gently pry the back off of the device.
    • Be sure not to pry too hard as it may result in snapping the back plate.
  2. Acer Chromebook C740-C4PE Touchpad Replacement: paso 2, imagen 1 de 1
    • Unscrew the two 5mm battery screws using the Phillips #0 screwdriver.
  3. Acer Chromebook C740-C4PE Touchpad Replacement: paso 3, imagen 1 de 1
    • Gently lift the battery up and away from the hooks on the bottom of the device keeping the battery in place.
    • Be sure the battery is away from the clips before pulling away so as not to break the clips.
  4. Acer Chromebook C740-C4PE Touchpad Replacement: paso 4, imagen 1 de 3 Acer Chromebook C740-C4PE Touchpad Replacement: paso 4, imagen 2 de 3 Acer Chromebook C740-C4PE Touchpad Replacement: paso 4, imagen 3 de 3
    • Detach the connecting cable from the motherboard by pulling away.
    • Remove the battery from the device.
  5. Acer Chromebook C740-C4PE Touchpad Replacement, Touchpad: paso 5, imagen 1 de 2 Acer Chromebook C740-C4PE Touchpad Replacement, Touchpad: paso 5, imagen 2 de 2
    • Unscrew the two screws on the silver restraint with the Phillips #0 screwdriver.
    • Lift the silver restraint from the device.
  6. Acer Chromebook C740-C4PE Touchpad Replacement: paso 6, imagen 1 de 1
    • Unscrew the five screws on the touchpad.
    • You will need to move aside the plastic covering that is above each screw.
  7. Acer Chromebook C740-C4PE Touchpad Replacement: paso 7, imagen 1 de 2 Acer Chromebook C740-C4PE Touchpad Replacement: paso 7, imagen 2 de 2
    • Using a spudger, lift the black electrical tape to the left of the touchpad.
    • Remove the black wire running across the touchpad from the two hooks on top of the part.
    • Be careful not to damage the black wire when removing from the two hooks.
  8. Acer Chromebook C740-C4PE Touchpad Replacement: paso 8, imagen 1 de 2 Acer Chromebook C740-C4PE Touchpad Replacement: paso 8, imagen 2 de 2
    • Lift the flap on the wire connecting the motherboard and remove the connector.
  9. Acer Chromebook C740-C4PE Touchpad Replacement: paso 9, imagen 1 de 1
    • Remove the touchpad from the device.
Conclusión
Jacob Kahn
Miembro Desde 10/17/17
273 Reputación
2 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 4
Ultimos 30 días: 11
Todo El Tiempo: 296
