Saltar al contenido principal
Acer Chromebook C740-C4PE Solid State Drive Replacement
Qué necesitas
  1. Acer Chromebook C740-C4PE Solid State Drive Replacement, Solid State Drive: paso 1, imagen 1 de 3 Acer Chromebook C740-C4PE Solid State Drive Replacement, Solid State Drive: paso 1, imagen 2 de 3 Acer Chromebook C740-C4PE Solid State Drive Replacement, Solid State Drive: paso 1, imagen 3 de 3
    • Make sure the laptop is turned off and laid down on a flat surface.
    • Unscrew the 13 screws on the back of the device using a PH0 Phillips head screwdriver.
    • Use the spudger or any other prying tool to pry the back plate off of the device.
    • Be sure not to pry too hard as it may result in snapping the back plate.
  2. Acer Chromebook C740-C4PE Solid State Drive Replacement: paso 2, imagen 1 de 3 Acer Chromebook C740-C4PE Solid State Drive Replacement: paso 2, imagen 2 de 3 Acer Chromebook C740-C4PE Solid State Drive Replacement: paso 2, imagen 3 de 3
    • Remove the 3.75 mm screw with a Phillips #0 screwdriver.
  3. Acer Chromebook C740-C4PE Solid State Drive Replacement: paso 3, imagen 1 de 1
    • Pull the Solid State Drive out of the connector.
Conclusión
Sang Huynh
Miembro Desde 03/08/17
252 Reputación
2 Guías creadas
Equipo
Un comentario
There are 2 types of SSD drives, m-SATA and M.2. Which does C740 use?
Guy Scree - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 16
Todo El Tiempo: 754
