Saltar al contenido principal
Acer Chromebook C740-C4PE LCD Screen Replacement
Qué necesitas
  1. Acer Chromebook C740-C4PE LCD Screen Replacement, LCD Screen: paso 1, imagen 1 de 1
    • Turn off the Acer Chromebook, remove it from the charger, and disconnect the battery adapter.
  2. Acer Chromebook C740-C4PE LCD Screen Replacement: paso 2, imagen 1 de 2 Acer Chromebook C740-C4PE LCD Screen Replacement: paso 2, imagen 2 de 2
    • Remove the black frame off the screen by using a spudger.
    • It is recommended to start removing the frame from the top corner.
  3. Acer Chromebook C740-C4PE LCD Screen Replacement: paso 3, imagen 1 de 2 Acer Chromebook C740-C4PE LCD Screen Replacement: paso 3, imagen 2 de 2
    • Use the spudger to open the two hinges that connect the screen frame to the bottom of the Chromebook.
    • Move the spudger along the bottom of the screen frame until you can pull the frame out entirely.
  4. Acer Chromebook C740-C4PE LCD Screen Replacement: paso 4, imagen 1 de 2 Acer Chromebook C740-C4PE LCD Screen Replacement: paso 4, imagen 2 de 2
    • Remove the four 3.4 mm screws by using the Phillips #0 screwdriver.
  5. Acer Chromebook C740-C4PE LCD Screen Replacement: paso 5, imagen 1 de 3 Acer Chromebook C740-C4PE LCD Screen Replacement: paso 5, imagen 2 de 3 Acer Chromebook C740-C4PE LCD Screen Replacement: paso 5, imagen 3 de 3
    • Place the LCD screen on top of the keyboard.
    • Lift the tape that holds the back of the LCD screen to the connector, and unplug the connector.
    • Remove the LCD screen and replace it with the new one.
Conclusión
3 personas más completaron esta guía.
Sang Huynh
Miembro Desde 03/08/17
252 Reputación
2 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 1
Ultimos 30 días: 12
Todo El Tiempo: 625
