Saltar al contenido principal
Acer Chromebook C740-C4PE Heatsink Replacement
Qué necesitas
  1. Acer Chromebook C740-C4PE Heatsink Replacement, Heatsink: paso 1, imagen 1 de 3 Acer Chromebook C740-C4PE Heatsink Replacement, Heatsink: paso 1, imagen 2 de 3 Acer Chromebook C740-C4PE Heatsink Replacement, Heatsink: paso 1, imagen 3 de 3
    • Make sure the laptop is turned off and laid down on a flat surface.
    • Unscrew the thirteen 10mm screws on the back of the device using a Phillips #0 screwdriver.
    • Use the spudger or any other prying tool to pry the back plate off of the device.
    • Be sure not to pry too hard as it may result in snapping the back plate.
  2. Acer Chromebook C740-C4PE Heatsink Replacement: paso 2, imagen 1 de 2 Acer Chromebook C740-C4PE Heatsink Replacement: paso 2, imagen 2 de 2
    • Remove the four 5mm screws on the heatsink using the Phillips #0 screwdriver.
  3. Acer Chromebook C740-C4PE Heatsink Replacement: paso 3, imagen 1 de 2 Acer Chromebook C740-C4PE Heatsink Replacement: paso 3, imagen 2 de 2
    • Loosen the two Phillips-head screws on the fan attached to the heatsink.
  4. Acer Chromebook C740-C4PE Heatsink Replacement: paso 4, imagen 1 de 1
    • Detach the two antennae cables from the WiFi card by gently pulling on them.
  5. Acer Chromebook C740-C4PE Heatsink Replacement: paso 5, imagen 1 de 1
    • Gently pull the fan cable out of the motherboard.
    • Pulling too hard may break the wires or the connector itself.
  6. Acer Chromebook C740-C4PE Heatsink Replacement: paso 6, imagen 1 de 1
    • Remove the cable routed through the fan.
    • Do not completely remove the cables as they are attached to the motherboard. Once they are no longer routed in the fan, leave them as they are.
  7. Acer Chromebook C740-C4PE Heatsink Replacement: paso 7, imagen 1 de 1
    • Remove the heatsink from the motherboard.
    • Before changing the heatsink/fan, you must clean off the thermal paste from the CPU and apply new thermal paste.
Conclusión
Una persona más ha completado esta guía.
Dylan Tocci
Miembro Desde 10/17/17
237 Reputación
2 Guías creadas
Equipo
Un comentario
What type of thermal paste is best used?
Tracey Arria - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 2
Ultimos 30 días: 12
Todo El Tiempo: 357
