Saltar al contenido principal
Acer Chromebook C740-C4PE Battery Replacement
Qué necesitas
  1. Acer Chromebook C740-C4PE Battery Replacement, Battery: paso 1, imagen 1 de 3 Acer Chromebook C740-C4PE Battery Replacement, Battery: paso 1, imagen 2 de 3 Acer Chromebook C740-C4PE Battery Replacement, Battery: paso 1, imagen 3 de 3
    • Make sure the laptop is turned off and unplugged before starting.
    • Unscrew the thirteen 10mm screws on the back of the computer using the Phillips #0 screwdriver.
    • Using the spudger or other prying tool, gently pry the back off of the device.
    • Be sure not to pry too hard as it may result in snapping the back plate.
  2. Acer Chromebook C740-C4PE Battery Replacement: paso 2, imagen 1 de 1
    • Unscrew the two 5mm battery screws using the Phillips #0 screwdriver.
  3. Acer Chromebook C740-C4PE Battery Replacement: paso 3, imagen 1 de 1
    • Gently lift the battery up and away from the hooks on the bottom of the device keeping the battery in place.
    • Be sure the battery is away from the clips before pulling away so as not to break the clips.
  4. Acer Chromebook C740-C4PE Battery Replacement: paso 4, imagen 1 de 3 Acer Chromebook C740-C4PE Battery Replacement: paso 4, imagen 2 de 3 Acer Chromebook C740-C4PE Battery Replacement: paso 4, imagen 3 de 3
    • Detach the connecting cable from the motherboard by pulling away.
    • Remove the battery from the device.
Conclusión
3 personas más completaron esta guía.
Jacob Kahn
Miembro Desde 10/17/17
273 Reputación
2 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 2
Ultimos 30 días: 9
Todo El Tiempo: 481
