Saltar al contenido principal
Acer Chromebook C740 Battery Replacement
Qué necesitas
  1. Acer Chromebook C740 Battery Replacement, Back Panel: paso 1, imagen 1 de 1
    • Power down the Chromebook and disconnect the power adapter.
  2. Acer Chromebook C740 Battery Replacement: paso 2, imagen 1 de 2 Acer Chromebook C740 Battery Replacement: paso 2, imagen 2 de 2
    • Place the chromebook bottom side up on a flat surface.
    • Remove the thirteen 7 mm screws with a Phillips #0 screwdriver.
  3. Acer Chromebook C740 Battery Replacement: paso 3, imagen 1 de 3 Acer Chromebook C740 Battery Replacement: paso 3, imagen 2 de 3 Acer Chromebook C740 Battery Replacement: paso 3, imagen 3 de 3
    • Insert the plastic opening tool into the slit near the hinges and pry upwards to lift the back panel.
    • Applying pressure may be necessary. A click indicates the panel is ready to come off.
  4. Acer Chromebook C740 Battery Replacement, Battery: paso 4, imagen 1 de 3 Acer Chromebook C740 Battery Replacement, Battery: paso 4, imagen 2 de 3 Acer Chromebook C740 Battery Replacement, Battery: paso 4, imagen 3 de 3
    • Unplug the white 8-wire battery connector from the motherboard by using a spudger to push the two L-shaped indentations towards the battery.
    • The connector is a tight fit. This process requires going back-and-forth between the two indentations and plenty of patience.
  5. Acer Chromebook C740 Battery Replacement: paso 5, imagen 1 de 2 Acer Chromebook C740 Battery Replacement: paso 5, imagen 2 de 2
    • Remove the the two 3.7 mm screws with a Phillips #0 screwdriver.
  6. Acer Chromebook C740 Battery Replacement: paso 6, imagen 1 de 1
    • Lift the battery from the frame.
Conclusión
7 personas más completaron esta guía.
Equipo
Cal Poly, Team S22-G2, Livingston Spring 2017 Miembro de Cal Poly, Team S22-G2, Livingston Spring 2017
CPSU-LIVINGSTON-S17S22G2
4 Miembros
12 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 13
Ultimos 30 días: 38
Todo El Tiempo: 7,308
