Saltar al contenido principal
Acer Chromebook C731-C8VE Wi-Fi Card Replacement
Qué necesitas
  1. Acer Chromebook C731-C8VE Wi-Fi Card Replacement, Wi-Fi Card: paso 1, imagen 1 de 1
    • Place Chromebook face down.
  2. Acer Chromebook C731-C8VE Wi-Fi Card Replacement: paso 2, imagen 1 de 2 Acer Chromebook C731-C8VE Wi-Fi Card Replacement: paso 2, imagen 2 de 2
    • Make sure to completely turn off the device before beginning this step.
    • Use a JIS #00 screwdriver to remove the 11 screws on the underside of the laptop.
    • These 2mm screws have washers and must be placed in these specific areas.
    • The 2mm screws marked orange do not have washers and will be placed on the left and right of the device.
  3. Acer Chromebook C731-C8VE Wi-Fi Card Replacement: paso 3, imagen 1 de 3 Acer Chromebook C731-C8VE Wi-Fi Card Replacement: paso 3, imagen 2 de 3 Acer Chromebook C731-C8VE Wi-Fi Card Replacement: paso 3, imagen 3 de 3
    • Use the iFixit opening tool to remove the keyboard from the device by prying it loose from the base.
  4. Acer Chromebook C731-C8VE Wi-Fi Card Replacement: paso 4, imagen 1 de 3 Acer Chromebook C731-C8VE Wi-Fi Card Replacement: paso 4, imagen 2 de 3 Acer Chromebook C731-C8VE Wi-Fi Card Replacement: paso 4, imagen 3 de 3
    • Detach the two wires that connect the Wi-Fi card to the screen.
    • The white wire will attach to the top and the black wire to the bottom.
  5. Acer Chromebook C731-C8VE Wi-Fi Card Replacement: paso 5, imagen 1 de 3 Acer Chromebook C731-C8VE Wi-Fi Card Replacement: paso 5, imagen 2 de 3 Acer Chromebook C731-C8VE Wi-Fi Card Replacement: paso 5, imagen 3 de 3
    • Use the JIS #00 screwdriver to unscrew the single 1mm screw connecting the Wi-Fi card to the base.
    • Once the screw is removed, the Wi-Fi card will pop up.
  6. Acer Chromebook C731-C8VE Wi-Fi Card Replacement: paso 6, imagen 1 de 3 Acer Chromebook C731-C8VE Wi-Fi Card Replacement: paso 6, imagen 2 de 3 Acer Chromebook C731-C8VE Wi-Fi Card Replacement: paso 6, imagen 3 de 3
    • Remove the Wi-Fi card from the motherboard.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 2
Todo El Tiempo: 173
