Saltar al contenido principal
Acer Chromebook C731-C8VE Trackpad Replacement
Qué necesitas
  1. Acer Chromebook C731-C8VE Trackpad Replacement, Trackpad: paso 1, imagen 1 de 1
    • Place the Chromebook face down.
  2. Acer Chromebook C731-C8VE Trackpad Replacement: paso 2, imagen 1 de 1
    • Make sure to completely turn off the device before beginning this step.
    • Use a JIS #00 screwdriver to remove the 11 screws on the underside of the laptop.
    • These 2 mm screws have washers and must be placed in these specific areas.
    • The 2 mm screws marked orange do not have washers attached and will be placed on the left and right of the device.
  3. Acer Chromebook C731-C8VE Trackpad Replacement: paso 3, imagen 1 de 3 Acer Chromebook C731-C8VE Trackpad Replacement: paso 3, imagen 2 de 3 Acer Chromebook C731-C8VE Trackpad Replacement: paso 3, imagen 3 de 3
    • Use the iFixit opening tool to remove the keyboard from the device by prying it loose from the base.
  4. Acer Chromebook C731-C8VE Trackpad Replacement: paso 4, imagen 1 de 3 Acer Chromebook C731-C8VE Trackpad Replacement: paso 4, imagen 2 de 3 Acer Chromebook C731-C8VE Trackpad Replacement: paso 4, imagen 3 de 3
    • Detach the wires connecting the keyboard and the touchpad to the motherboard by lifting the black connectors up.
  5. Acer Chromebook C731-C8VE Trackpad Replacement: paso 5, imagen 1 de 2 Acer Chromebook C731-C8VE Trackpad Replacement: paso 5, imagen 2 de 2
    • Use the JIS #00 screwdriver to remove four 1mm screws that connect the trackpad to the device.
  6. Acer Chromebook C731-C8VE Trackpad Replacement: paso 6, imagen 1 de 2 Acer Chromebook C731-C8VE Trackpad Replacement: paso 6, imagen 2 de 2
    • Do this step slowly to ensure that you do not damage the trackpad or the device.
    • Remove the trackpad from the base of the device.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 4
Ultimos 30 días: 6
Todo El Tiempo: 179
