Introducción
This guide explains how to remove the solid state drive. Before removing the solid state drive, the back panel assembly needs to be removed. Once the back panel assembly is removed, the solid state drive can be quickly unscrewed and pulled out.
Qué necesitas
Remove the thirteen 6.0mm screws on the back panel using your Phillips #1 screwdriver.
Remove the single 3.0mm screw securing the solid state drive using a Phillips #1 screwdriver.
2 personas más completaron esta guía.
