Saltar al contenido principal
Acer Chromebook C720-2827 RAM Replacement
Qué necesitas
  1. Acer Chromebook C720-2827 RAM Replacement, Back Panel Assembly: paso 1, imagen 1 de 2 Acer Chromebook C720-2827 RAM Replacement, Back Panel Assembly: paso 1, imagen 2 de 2
    • Remove the thirteen 6.0mm screws on the back panel using your Phillips #1 screwdriver.
  2. Acer Chromebook C720-2827 RAM Replacement: paso 2, imagen 1 de 2 Acer Chromebook C720-2827 RAM Replacement: paso 2, imagen 2 de 2
    • Pry the back panel open with the plastic opening tool.
  3. Acer Chromebook C720-2827 RAM Replacement, Battery: paso 3, imagen 1 de 1
    • Remove the two 6.0mm screws securing the battery with your Phillips #1 screwdriver.
  4. Acer Chromebook C720-2827 RAM Replacement: paso 4, imagen 1 de 2 Acer Chromebook C720-2827 RAM Replacement: paso 4, imagen 2 de 2
    • Carefully pull out the battery wire connected to the battery port.
  5. Acer Chromebook C720-2827 RAM Replacement: paso 5, imagen 1 de 1
    • Slowly lift the battery to remove it from the Chromebook.
  6. Acer Chromebook C720-2827 RAM Replacement, Speakers: paso 6, imagen 1 de 2 Acer Chromebook C720-2827 RAM Replacement, Speakers: paso 6, imagen 2 de 2
    • Unplug the speaker wire from the motherboard.
  7. Acer Chromebook C720-2827 RAM Replacement: paso 7, imagen 1 de 2 Acer Chromebook C720-2827 RAM Replacement: paso 7, imagen 2 de 2
    • Carefully pull out the speakers from each side of the Chromebook.
  8. Acer Chromebook C720-2827 RAM Replacement, Solid State Drive: paso 8, imagen 1 de 2 Acer Chromebook C720-2827 RAM Replacement, Solid State Drive: paso 8, imagen 2 de 2
    • Remove the single 3.0mm screw securing the solid state drive using a Phillips #1 screwdriver.
  9. Acer Chromebook C720-2827 RAM Replacement: paso 9, imagen 1 de 2 Acer Chromebook C720-2827 RAM Replacement: paso 9, imagen 2 de 2
    • Carefully pull out the solid state drive using two fingers.
  10. Acer Chromebook C720-2827 RAM Replacement, USB Port/SD Card Reader: paso 10, imagen 1 de 3 Acer Chromebook C720-2827 RAM Replacement, USB Port/SD Card Reader: paso 10, imagen 2 de 3 Acer Chromebook C720-2827 RAM Replacement, USB Port/SD Card Reader: paso 10, imagen 3 de 3
    • Remove the three 6.0mm screws using the Phillips #1 screwdriver.
    • Remove the two 3.0mm screws using the Phillips #1 screwdriver.
  11. Acer Chromebook C720-2827 RAM Replacement: paso 11, imagen 1 de 2 Acer Chromebook C720-2827 RAM Replacement: paso 11, imagen 2 de 2
    • Position the spudger under the switch that connects the ribbon cable to the motherboard.
    • Flick the spudger up to flip the switch up.
  12. Acer Chromebook C720-2827 RAM Replacement: paso 12, imagen 1 de 2 Acer Chromebook C720-2827 RAM Replacement: paso 12, imagen 2 de 2
    • Pull the blue tab on the ribbon cable to remove it.
  13. Acer Chromebook C720-2827 RAM Replacement: paso 13, imagen 1 de 2 Acer Chromebook C720-2827 RAM Replacement: paso 13, imagen 2 de 2
    • Grab the edges of each piece of circuitry that is included with the SD Card Reader and USB Port.
    • Pull each piece of circuitry out of the Chromebook and remove it from the device.
  14. Acer Chromebook C720-2827 RAM Replacement: paso 14, imagen 1 de 2 Acer Chromebook C720-2827 RAM Replacement: paso 14, imagen 2 de 2
    • Position the spudger under the switch.
  15. Acer Chromebook C720-2827 RAM Replacement: paso 15, imagen 1 de 2 Acer Chromebook C720-2827 RAM Replacement: paso 15, imagen 2 de 2
    • Pull on the blue tab of the ribbon cable to remove the ribbon cable.
    • Repeat the previous step and this step with the other ribbon cable that is attached to the SD Card Reader/USB Port.
  16. Acer Chromebook C720-2827 RAM Replacement, Motherboard: paso 16, imagen 1 de 2 Acer Chromebook C720-2827 RAM Replacement, Motherboard: paso 16, imagen 2 de 2
    • Using the Phillips #1 screwdriver, remove the four 3.0mm screws.
    • Loosen the six 3.0mm CPU screws using the Phillips #1 screwdriver.
    • The six 3.0mm CPU screws do not come out of the motherboard.
  17. Acer Chromebook C720-2827 RAM Replacement: paso 17, imagen 1 de 2 Acer Chromebook C720-2827 RAM Replacement: paso 17, imagen 2 de 2
    • Grab the wire for the two pin connector.
    • Pull the wire to disconnect it from the motherboard.
  18. Acer Chromebook C720-2827 RAM Replacement: paso 18, imagen 1 de 2 Acer Chromebook C720-2827 RAM Replacement: paso 18, imagen 2 de 2
    • Place the back of the spudger under the black wire that connects the wireless card to the motherboard.
    • Flick the spudger up to disconnect the cable from the motherboard.
  19. Acer Chromebook C720-2827 RAM Replacement: paso 19, imagen 1 de 2 Acer Chromebook C720-2827 RAM Replacement: paso 19, imagen 2 de 2
    • Place the back of the spudger under the white coaxial antenna wire that connects the wireless card to the motherboard.
  20. Acer Chromebook C720-2827 RAM Replacement: paso 20, imagen 1 de 2 Acer Chromebook C720-2827 RAM Replacement: paso 20, imagen 2 de 2
    • Take both wires and unravel them from the CPU fan.
  21. Acer Chromebook C720-2827 RAM Replacement: paso 21, imagen 1 de 2 Acer Chromebook C720-2827 RAM Replacement: paso 21, imagen 2 de 2
    • Firmly grasp the red, yellow, and white cords with two fingers.
    • Pull the cords to unplug it.
  22. Acer Chromebook C720-2827 RAM Replacement: paso 22, imagen 1 de 2 Acer Chromebook C720-2827 RAM Replacement: paso 22, imagen 2 de 2
    • Position the spudger under the switch of the big ribbon cable.
  23. Acer Chromebook C720-2827 RAM Replacement: paso 23, imagen 1 de 2 Acer Chromebook C720-2827 RAM Replacement: paso 23, imagen 2 de 2
    • Grab the blue tab of the ribbon cable.
    • Pull on the blue tab to disconnect the ribbon cable.
  24. Acer Chromebook C720-2827 RAM Replacement: paso 24, imagen 1 de 3 Acer Chromebook C720-2827 RAM Replacement: paso 24, imagen 2 de 3 Acer Chromebook C720-2827 RAM Replacement: paso 24, imagen 3 de 3
    • Grab the red and black cable near the display cables, this is the cable to the other two pin connector.
    • Pull on the wire to disconnect it from the motherboard.
    • Flip the wire and the connector up to move it out of the way.
  25. Acer Chromebook C720-2827 RAM Replacement: paso 25, imagen 1 de 2 Acer Chromebook C720-2827 RAM Replacement: paso 25, imagen 2 de 2
    • Position the spudger under the switch for the smaller ribbon cable.
    • Flick the spudger up to flip the smaller switch up.
  26. Acer Chromebook C720-2827 RAM Replacement: paso 26, imagen 1 de 2 Acer Chromebook C720-2827 RAM Replacement: paso 26, imagen 2 de 2
    • Grab the blue tab on the ribbon cable.
    • Pull on the tab to disconnect the ribbon cable from the motherboard.
  27. Acer Chromebook C720-2827 RAM Replacement: paso 27, imagen 1 de 2 Acer Chromebook C720-2827 RAM Replacement: paso 27, imagen 2 de 2
    • Position the back of the spudger at the edge of the tape that holds the display cable in.
    • Peel the tape back so it is out of the way.
  28. Acer Chromebook C720-2827 RAM Replacement: paso 28, imagen 1 de 2 Acer Chromebook C720-2827 RAM Replacement: paso 28, imagen 2 de 2
    • Position the back of the spudger on the display cable.
    • Push the display cable out using the back of the spudger.
  29. Acer Chromebook C720-2827 RAM Replacement: paso 29, imagen 1 de 2 Acer Chromebook C720-2827 RAM Replacement: paso 29, imagen 2 de 2
    • Lift up the CPU fan to ensure that no wires are tangled. If the black and white wires are tangles please repeat step 5.
    • Lift up the other end of the motherboard to completely remove the motherboard.
  30. Acer Chromebook C720-2827 RAM Replacement, RAM: paso 30, imagen 1 de 1
  31. Acer Chromebook C720-2827 RAM Replacement: paso 31, imagen 1 de 1
    • Put the new RAM in place of the old RAM.
    • Carefully solder the new RAM into place.
Conclusión
Una persona más ha completado esta guía.
Kennedy Morales
Miembro Desde 10/20/17
655 Reputación
6 Guías creadas
Equipo
Un comentario
Can you link the ram parts?
Tyler OHara - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 10
Ultimos 30 días: 70
Todo El Tiempo: 3,392
