Introducción
This guide explains how to replace your Chromebook's RAM. You will need to remove the Back Panel Assembly first. Then, you will need to remove the Battery and Speakers. Next, you will need to remove the Hard Drive. Then, you will need to remove the USB ports / SD Card Reader. After, you will need to take the Motherboard out to get to the RAM.
Qué necesitas
Remove the thirteen 6.0mm screws on the back panel using your Phillips #1 screwdriver.
Remove the two 6.0mm screws securing the battery with your Phillips #1 screwdriver.
Remove the single 3.0mm screw securing the solid state drive using a Phillips #1 screwdriver.
Remove the three 6.0mm screws using the Phillips #1 screwdriver.
Remove the two 3.0mm screws using the Phillips #1 screwdriver.
Using the Phillips #1 screwdriver, remove the four 3.0mm screws.
Loosen the six 3.0mm CPU screws using the Phillips #1 screwdriver.
Carefully desolder the sides of the old RAM using a soldering iron.
For soldering help, visit iFixit's How to Solder and Desolder Connections guide.
Una persona más ha completado esta guía.
