Introducción
This guide will provide you with the most practical way to remove the memory card off your C720-2420 Chromebook with a couple of steps.
  1. Place your Chromebook upside down. Utilizing the precision magnetized Phillips #0 screwdriver, remove all thirteen 6.5 mm Phillips screws that secure the back cover.
    • Place your Chromebook upside down.
    • Utilizing the precision magnetized Phillips #0 screwdriver, remove all thirteen 6.5 mm Phillips screws that secure the back cover.
    • Before doing anything, make sure your Acer Chromebook is completely turned off.
  2. Use the plastic opening tool to carefully remove the bottom.
    • Use the plastic opening tool to carefully remove the bottom.
  3. ¡Envío gratuito para todos los pedidos de más de USD100 o que contengan un Pro Tech Toolkit!
    Visita Nuestra Tienda
  4. Remove the 3.6 mm  Phillips screw that secures the SSD in place. Remove the 3.6 mm  Phillips screw that secures the SSD in place.
    • Remove the 3.6 mm Phillips screw that secures the SSD in place.
  5. Pull out the SSD. Pull out the SSD.
    • Pull out the SSD.
Conclusión
2 personas más completaron esta guía.
Equipo
USF Tampa, Team S15-G4, Boczar Spring 2018 Miembro de USF Tampa, Team S15-G4, Boczar Spring 2018
USFT-BOCZAR-S18S15G4
4 Miembros
6 Guías creadas
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 1
Todo El Tiempo: 61
