Introducción
This guide will provide you with simple and clear steps on how to remove the fan on your Acer Chromebook C720-2420.
  1. Place your Chromebook upside down. Utilizing the precision magnetized Phillips #0 screwdriver, remove all thirteen 6.5 mm Phillips screws that secure the back cover.
    • Place your Chromebook upside down.
    • Utilizing the precision magnetized Phillips #0 screwdriver, remove all thirteen 6.5 mm Phillips screws that secure the back cover.
    • Before doing anything, make sure your Acer Chromebook is completely turned off.
  2. Use the plastic opening tool to carefully remove the bottom.
    • Use the plastic opening tool to carefully remove the bottom.
  3. Remove the two 3.6 mm Phillips screws holding the battery in place. Remove the two 3.6 mm Phillips screws holding the battery in place.
    • Remove the two 3.6 mm Phillips screws holding the battery in place.
  4. ¡Envío gratuito para todos los pedidos de más de USD100 o que contengan un Pro Tech Toolkit!
    Visita Nuestra Tienda
  5. Disconnect the connector that attaches the battery to the Chromebook with a pair of pliers or tweezers. Alternatively, you could use your hands, as it may be difficult to unhook the connector.
    • Disconnect the connector that attaches the battery to the Chromebook with a pair of pliers or tweezers.
    • Alternatively, you could use your hands, as it may be difficult to unhook the connector.
  6. Remove the battery.
    • Remove the battery.
  7. Remove the six 4.7 mm Phillips screws that secure the fan. Remove the six 4.7 mm Phillips screws that secure the fan.
    • Remove the six 4.7 mm Phillips screws that secure the fan.
  8. Disconnect these cables from the motherboard using the tweezers. Alternatively, you may use your hands. Pull out the fan.
    • Disconnect these cables from the motherboard using the tweezers.
    • Alternatively, you may use your hands.
    • Pull out the fan.
Conclusión
Equipo
USF Tampa, Team S15-G4, Boczar Spring 2018 Miembro de USF Tampa, Team S15-G4, Boczar Spring 2018
USFT-BOCZAR-S18S15G4
4 Miembros
6 Guías creadas
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 0
Todo El Tiempo: 48
