Saltar al contenido principal
Acer Chromebook C720-2103 Solid State Drive Replacement
Qué necesitas
  1. Acer Chromebook C720-2103 Solid State Drive Replacement, Battery: paso 1, imagen 1 de 2 Acer Chromebook C720-2103 Solid State Drive Replacement, Battery: paso 1, imagen 2 de 2
    • Shut the device off.
    • Turn the device over so the bottom is facing up.
    • Remove all thirteen 6mm screws using a Phillips #0 screwdriver.
    • Remember to keep screws separated by step and their locations in the device. This will help prevent confusion during reassembly.
    • Removing the battery is necessary to prevent electric shock during part replacement.
  2. Acer Chromebook C720-2103 Solid State Drive Replacement: paso 2, imagen 1 de 1
    • Wedge a plastic opening tool between the back casing and the rest of the device.
    • Apply pressure up and down carefully, until backing pops up. Repeat this process in multiple spots if needed.
    • It is easiest to start at the back of the device, between the hinges of the screen.
    • Do not apply too much force. This will crack the plastic.
  3. Acer Chromebook C720-2103 Solid State Drive Replacement: paso 3, imagen 1 de 1
    • Remove the three 6mm screws indicated by the red circles with a Phillips #0 screwdriver.
  4. Acer Chromebook C720-2103 Solid State Drive Replacement: paso 4, imagen 1 de 2 Acer Chromebook C720-2103 Solid State Drive Replacement: paso 4, imagen 2 de 2
    • Pull the rainbow cable connector out of the white terminal by wiggling it gently from side to side with your fingers.
    • Be careful when removing the cable. Too much force can damage the motherboard or the cable connector.
  5. Acer Chromebook C720-2103 Solid State Drive Replacement: paso 5, imagen 1 de 2 Acer Chromebook C720-2103 Solid State Drive Replacement: paso 5, imagen 2 de 2
    • Lift the battery straight up and out of the device with your hands. Take care not to knock the battery against another component.
  6. Acer Chromebook C720-2103 Solid State Drive Replacement, Solid State Drive: paso 6, imagen 1 de 1
    • Remove one 6mm screw using a Phillips #0 screwdriver.
  7. Acer Chromebook C720-2103 Solid State Drive Replacement: paso 7, imagen 1 de 3 Acer Chromebook C720-2103 Solid State Drive Replacement: paso 7, imagen 2 de 3 Acer Chromebook C720-2103 Solid State Drive Replacement: paso 7, imagen 3 de 3
    • Carefully remove the solid state drive from the solid state drive slot by sliding it downward away from the motherboard.
Conclusión
2 personas más completaron esta guía.
Matthew Holt
Miembro Desde 10/17/17
633 Reputación
5 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 8
Todo El Tiempo: 277
