Saltar al contenido principal
Acer Chromebook C720 Heat Sink and Cooling Fan Replacement
Qué necesitas
  1. Acer Chromebook C720 Heat Sink and Cooling Fan Replacement, Heat Sink and Cooling Fan: paso 1, imagen 1 de 3 Acer Chromebook C720 Heat Sink and Cooling Fan Replacement, Heat Sink and Cooling Fan: paso 1, imagen 2 de 3 Acer Chromebook C720 Heat Sink and Cooling Fan Replacement, Heat Sink and Cooling Fan: paso 1, imagen 3 de 3
    • Operating on your device while it is on, or plugged in may result in electrical shock. Make sure the device is not powered before continuing.
    • Remove the thirteen 6mm screws using the Phillips #0 screwdriver.
    • Gently pry the back plate off using the plastic opening tool, leveraging the groove along the device's hinge.
  2. Acer Chromebook C720 Heat Sink and Cooling Fan Replacement: paso 2, imagen 1 de 2 Acer Chromebook C720 Heat Sink and Cooling Fan Replacement: paso 2, imagen 2 de 2
    • Remove the four 3mm screws securing the heat sink using the Phillips #0 screwdriver.
    • Remove the two 3mm screws securing the fan using the Phillips #0 screwdriver.
  3. Acer Chromebook C720 Heat Sink and Cooling Fan Replacement: paso 3, imagen 1 de 2 Acer Chromebook C720 Heat Sink and Cooling Fan Replacement: paso 3, imagen 2 de 2
    • Gently pry the fan module away from the motherboard. After a bit of force, it should pop out of its slot.
    • Carefully unwrap the wires from around the fan.
  4. Acer Chromebook C720 Heat Sink and Cooling Fan Replacement: paso 4, imagen 1 de 3 Acer Chromebook C720 Heat Sink and Cooling Fan Replacement: paso 4, imagen 2 de 3 Acer Chromebook C720 Heat Sink and Cooling Fan Replacement: paso 4, imagen 3 de 3
    • Gently disconnect the fan module from the motherboard.
Conclusión
2 personas más completaron esta guía.
Benjamin Rahman
Miembro Desde 04/01/19
517 Reputación
3 Guías creadas
Equipo
IUPUI, Team S2-G5, Harley Spring 2019 Miembro de IUPUI, Team S2-G5, Harley Spring 2019
IUPUI-HARLEY-S19S2G5
4 Miembros
7 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 6
Todo El Tiempo: 536
