Saltar al contenido principal
Qué necesitas
  1. Acer Chromebook C710-2856 Motherboard Replacement, RAM: paso 1, imagen 1 de 2 Acer Chromebook C710-2856 Motherboard Replacement, RAM: paso 1, imagen 2 de 2
    • Remove the one 4.3mm Phillips #1 screw holding the back cover on.
  2. Acer Chromebook C710-2856 Motherboard Replacement: paso 2, imagen 1 de 1
    • Locate the RAM and the metal clips holding the RAM in place.
  3. Acer Chromebook C710-2856 Motherboard Replacement: paso 3, imagen 1 de 2 Acer Chromebook C710-2856 Motherboard Replacement: paso 3, imagen 2 de 2
    • Push the two clips outwards at the same time with your fingers. The RAM will gently pop upwards.
  4. Acer Chromebook C710-2856 Motherboard Replacement: paso 4, imagen 1 de 1
    • Pull the RAM out of the slot.
  5. Acer Chromebook C710-2856 Motherboard Replacement, Wi-Fi Card: paso 5, imagen 1 de 3 Acer Chromebook C710-2856 Motherboard Replacement, Wi-Fi Card: paso 5, imagen 2 de 3 Acer Chromebook C710-2856 Motherboard Replacement, Wi-Fi Card: paso 5, imagen 3 de 3
    • Using the Phillips #1 screwdriver, remove the screw from the Wi-Fi card.
    • Carefully remove the piece of tape to allow for more room to remove the Wi-Fi card.
    • Use the blue plastic opening tool to lift and remove the Wi-Fi card from its socket.
  6. Acer Chromebook C710-2856 Motherboard Replacement: paso 6, imagen 1 de 3 Acer Chromebook C710-2856 Motherboard Replacement: paso 6, imagen 2 de 3 Acer Chromebook C710-2856 Motherboard Replacement: paso 6, imagen 3 de 3
    • Use the blue plastic opening tool and carefully remove the connectors from the Wi-Fi card.
  7. Acer Chromebook C710-2856 Motherboard Replacement: paso 7, imagen 1 de 2 Acer Chromebook C710-2856 Motherboard Replacement: paso 7, imagen 2 de 2
    • Remove the Wi-Fi card.
  8. Acer Chromebook C710-2856 Motherboard Replacement, Motherboard: paso 8, imagen 1 de 1
    • Unscrew the circled screws, a total of 17 (15 M 2x6 and 2 M 2x3), with a cross-head screwdriver.
  9. Acer Chromebook C710-2856 Motherboard Replacement: paso 9, imagen 1 de 3 Acer Chromebook C710-2856 Motherboard Replacement: paso 9, imagen 2 de 3 Acer Chromebook C710-2856 Motherboard Replacement: paso 9, imagen 3 de 3
    • Using the blue plastic opening tool, work your way around the perimeter of the laptop and remove the bottom frame.
    • Be careful though, because we will not be pulling it completely apart since we will need to disconnect 2 ribbon cables first (shown in next step).
  10. Acer Chromebook C710-2856 Motherboard Replacement: paso 10, imagen 1 de 2 Acer Chromebook C710-2856 Motherboard Replacement: paso 10, imagen 2 de 2
    • Remove the green ribbon on the backside of the laptop by pulling on it lightly as shown.
    • Gently remove the back ribbon that is holding the two parts of the laptop together (found between the two parts that are being pulling apart).
  11. Acer Chromebook C710-2856 Motherboard Replacement: paso 11, imagen 1 de 1
    • Now completely pull apart the motherboard from the underside of the laptop by pulling on the location of the arrows.
  12. Acer Chromebook C710-2856 Motherboard Replacement: paso 12, imagen 1 de 3 Acer Chromebook C710-2856 Motherboard Replacement: paso 12, imagen 2 de 3 Acer Chromebook C710-2856 Motherboard Replacement: paso 12, imagen 3 de 3
    • Disconnect the five ribbons by pulling gently on the ribbon.
    • Unscrew the M2x3 screw.
    • Disconnect the blue connector from the motherboard.
    • Disconnect the wider white connector from the motherboard.
  13. Acer Chromebook C710-2856 Motherboard Replacement: paso 13, imagen 1 de 2 Acer Chromebook C710-2856 Motherboard Replacement: paso 13, imagen 2 de 2
    • Remove the motherboard from the frame.
  14. Acer Chromebook C710-2856 Motherboard Replacement: paso 14, imagen 1 de 3 Acer Chromebook C710-2856 Motherboard Replacement: paso 14, imagen 2 de 3 Acer Chromebook C710-2856 Motherboard Replacement: paso 14, imagen 3 de 3
    • Remove the fan by unscrewing two M2x3 screws.
    • Peel the tape off the ribbon connection for easy access.
    • Use the plastic opening tool to disconnect the connector.
  15. Acer Chromebook C710-2856 Motherboard Replacement: paso 15, imagen 1 de 2 Acer Chromebook C710-2856 Motherboard Replacement: paso 15, imagen 2 de 2
    • Remove the fan.
  16. Acer Chromebook C710-2856 Motherboard Replacement: paso 16, imagen 1 de 1
    • The motherboard is now bare of any extras and is ready to be replaced.
Conclusión
Vladimir
Miembro Desde 27/09/17
101 Reputación
1 Guía escrita
Equipo
USF Tampa, Team S6-G5, Remmell Fall 2017 Miembro de USF Tampa, Team S6-G5, Remmell Fall 2017
USFT-REMMELL-F17S6G5
7 Miembros
8 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 6
Todo El Tiempo: 561
