Saltar al contenido principal
Acer Chromebook C710-2847 Back Cover Replacement
Qué necesitas
  1. Acer Chromebook C710-2847 Back Cover Replacement, Battery: paso 1, imagen 1 de 2 Acer Chromebook C710-2847 Back Cover Replacement, Battery: paso 1, imagen 2 de 2
    • Place the laptop on a flat surface with the bottom side facing up.
    • Place the tip of a spudger or finger into the hole on the battery release slider.
  2. Acer Chromebook C710-2847 Back Cover Replacement: paso 2, imagen 1 de 2 Acer Chromebook C710-2847 Back Cover Replacement: paso 2, imagen 2 de 2
    • Use the spudger to move the slider to the right and hold it there.
    • With the slider held, use your other hand to pull the battery back away from the laptop.
  3. Acer Chromebook C710-2847 Back Cover Replacement, Acer Chromebook C710-2847 Back Cover Replacement: paso 3, imagen 1 de 1
    • This step will void your device warranty.
    • Use the screwdriver to pierce the warranty sticker.
    • Unscrew and remove the #0 6mm Phillips screw and set it aside.
  4. Acer Chromebook C710-2847 Back Cover Replacement: paso 4, imagen 1 de 2 Acer Chromebook C710-2847 Back Cover Replacement: paso 4, imagen 2 de 2
    • Slide the back panel towards you. The best spots to place your fingers are on the bumpers.
    • Lift on the front edge to remove the panel.
Conclusión
9 personas más completaron esta guía.
Bradley Pavy
Miembro Desde 09/30/13
1,257 Reputación
6 Guías creadas
Equipo
Cal Poly, Team 13-3, Forte Fall 2013 Miembro de Cal Poly, Team 13-3, Forte Fall 2013
CPSU-FORTE-F13S13G3
5 Miembros
14 Guías creadas
Un comentario
Once you have the back cover off, you can insert aluminum foil into a tiny connector, which will allow you to flash the BIOS and boot any operating system, not just ChromeOS. Using this method, I completely wiped ChromeOS from my C710 and installed Ubuntu 16.04 LTS. Definitely worth it, because now I have a sub-$300 Linux netbook with a removable battery, standard keyboard with CAPS lock (most Chromebooks don't), and no ugly Windows key.
Uncle Happy - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 11
Todo El Tiempo: 6,338
